New Printer
Sues
New Printer
Don't know if anyone can help but i need to buy a new printer and the one I'm interested in buying says you have to initially press the WPS button on the router to connect it to wifi. My Plusnet router hasn't got a WPS button. Anyone know what I do to get round not pressing a WPS button I haven't got and get it to connect? Thanks for any info you can supply. The printer I have at the moment just connects to wifi as soon as you turn it on!
4 REPLIES 4
Gel
Aspiring Champion
Fixes: 27
Re: New Printer
You don't say what model of PN Router you have.
See here;
https://www.plus.net/help/broadband/router-setup-guides/
PN's Hub One definitely has WPS button.
If your existing printer connects automatically have you previously input the Router's password so the 2 can handshake?
If not, it looks like your Router has no wifi security, which means anyone can piggyback on your B Band connection.
Sues
Re: New Printer
Sorry, just found it! Don't know what type of  Plusnet router I have but I was looking for a button on the back. It is in fact a little two pronged thing on the side with a sign on it that looks like two quotation marks. I assume the WPS light is supposed to switch itself off after a short while? Thanks.
Aspiring Legend
Fixes: 196
Re: New Printer
@Sues The WPS light will switch off once the printer is connected to the router - or fairly soon after.
Sues
Re: New Printer
Thank you so much.
