New Plusnet routers come pre-programmed?
selector
I was reading the printable setup guide for the Thomson 585v7 router and in step 1 it mentions that from Spring 2009 Plusnet will have a system that will automatically set up the connection for you. Is this now in place?
scootie
Re: New Plusnet routers come pre-programmed?
i dont think it's gone live yet Undecided
The system that is planned relies on a feature called 'TR-069', whereby a router will, on first connection, automatically pick up it's required settings from a central server hosted by Plusnet.
Some initial trials of the solution were very promising, but I don't believe that it has been deployed as yet.
B.
James
Nope.  We've not done this yet, but are hoping to do so soon.
We're only just into Spring though Smiley
