New Plusnet Fibre Speed ?
- New Plusnet Fibre Speed ?
Re: New Plusnet Fibre Speed ?
04-04-2013 1:58 AM
http://community.plus.net/library/broadband/fibre-help-setting-up-a-pppoe-dialler-for-windows-xp/ or
http://community.plus.net/library/broadband/fibre-help-how-to-set-up-a-pppoe-dialler-in-vistawindows... for guidance.
04-04-2013 2:33 AM
04-04-2013 5:24 AM
I was having similar results from BTW to yourself, using Firefox as my browser.
Went over to IE and Google Chrome, ran the same tests and was now showing what I should be getting.
Although I could be talking xxxxxxxxxx
04-04-2013 8:01 AM
04-04-2013 12:11 PM
04-04-2013 1:27 PM
I've checked over your connection and you're currently syncing in the high 70Mb/s. Have you been able to try a PPPoE conenction?
Quote from: Anotherone It's definitely looking like a problem. That's pretty consistent on two Gateways.If a 3rd is the same then, the other thing you can try is eliminating the Router, by connecting your computer direct to the modem and setting up a PPPoE dialler. See
Also trying an alternative browser as suggested would be the next step.
04-04-2013 4:51 PM
here is the results when running through chrome:
1. Best Effort Test: -provides background information.
Download speed achieved during the test was - 75.53 Mbps
For your connection, the acceptable range of speeds is 16 Mbps-77.44 Mbps .
Additional Information:
IP Profile for your line is - 77.44 Mbps
Upload speed achieved during the test was - 15.81Mbps
Anyone know why there is poor download performance through Firefox?
thanks to all for their input
05-04-2013 6:47 AM
Download 73.49Mbps
Upload 15.46Mbps
Ping Latency 17.50
These figures are roughly what I expected looking at my line capability.
The only problem is.......IE 10 is painfully slow to load up pages. It's almost like being on dial up.
05-04-2013 10:01 AM
Managed to get results and diagnostics from the BTW. Seems even slower now. This is using Wireless so will try with a wired connection.
This was run using Safari browser on Mac.
Here are my current results:
Download Speed
16.58 Mbps
0 Mbps 77.44 Mbps
Max Achievable Speed
Download speedachieved during the test was - 16.58 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-77.44 Mbps .
Upload Speed
4.38 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 4.38Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
05-04-2013 10:05 AM
Date Download Speed Upload Speed
Today 10:05 28189 kbps (3.52MB/s) 15061 kbps (1.88MB/s)
very confusing...
05-04-2013 10:09 AM
Second time it was 29.02 down and 7.52 up varying all the time again using wireless.
05-04-2013 10:13 AM
Quote from: twen and mybroadbandspeed.co.uk reports
very confusing...
Don't use mybroadbandspeed. It can't handle fibre speed tests properly.
Ex-Broadband Service Manager
05-04-2013 10:20 AM
Quote from: Smufter The only problem is.......IE 10 is painfully slow to load up pages. It's almost like being on dial up.
I would do a few things...
Reset IE Settings - Tools > Internet Options > Advanced > Reset (you can choose to Delete Personal Settings too)
Check the Add Ons - Tools > Manage add-ons > Under Show, tap or click All add-ons
Make sure Flash is up-to-date - http://helpx.adobe.com/flash-player/kb/find-version-flash-player.html
Edit: I would also try running this http://secunia.com/vulnerability_scanning/online/ It checks all your programs to make sure they're all up-to-date with the latest versions
05-04-2013 10:25 AM
Quote from: twen reran BTW again twice first was 42Mb down and about 12up.
Try speedtest.net - It generally gives me the best speeds out of all the checkers. It's also useful as it logs and graphs your speeds for you to review.
Have a play around with http://www.netspotapp.com/ which is a Mac WiFi survey tool - (bit of a guide here)
; It will allow you to fine tune the wireless performance of the router by measuring signal strength (you can tweak things like changing channel/angle of router to see how that affects things)
05-04-2013 9:15 PM
which version of Firefox were you each running and on what OS?
