New PlusNet router is slower than my 12 year old Netgear
DavMcCC
Having over the past many weeks slow ever thing. connecting, downloading, uploading, Amazon fire-stick sits and buffs ? I am just getting feed up with the hold lot, so I phoned plusnet on 0800 432 0200 and it didn't work either, it just kept ging over and over the same message..  also I got a phone call while I was typing this, the connection so bad I could just about hear the other person speak !
New router made no difference, fitted a new mark 6 wall plate master socket, with new filter, no change
Done a line test the screen shot is the best speed I have seen in a long time, but in real life the upload is an average of 128kbs and the download is about 300kbs
I use to get the max download speed of 18mb + on testing the line but not any longer
Any help would be nice
5 REPLIES 5
Strat
Fixes: 565
Re: New PlusNet router is slower than my 12 year old Netgear
Moderator's note by Dick (Strat): Post released from Spam Filter.
TheMightyAJ
Fixes: 126
Hi @DavMcCC,
I'm sorry to hear that you're experiencing these issues. To help us better diagnose where the problem lies, please can you clarify if you are also experiencing issues with the phone line as well as with the broadband?
 Alex H
Jonpe
Fixes: 9
OP stated, "... also I got a phone call while I was typing this, the connection so bad I could just about hear the other person speak !" so yes, I'd say so.
Fixes: 419
@DavMcCC
You will never get decent broadband if your telephone line is poor. Ring 17070 and select the quiet line test option. If there's noise on the line then report a phone not broadband fault to however supplies your telephone service (some people use a different company rather than Plusnet).
If you are with Plusnet then this may help. https://www.plus.net/help/phone/phone-line-troubleshooting/ If you follow through the links to the troubleshooter I understand that the system will automatically report a fault without you having to hang on the phone.
When you have a quiet line then that's the time to address any remaining broadband speed issues, should they still be present.
adamwalker
Fixes: 221
Hi  DavMcCC,
I've just been testing your line but don't see any obvious issues. We've reported a fault so you should hear back from us about that soon.
Adam
 Adam Walker
