New Netgear Wireless - causing PC boot up to take 20 mins!
- New Netgear Wireless - causing PC boot up to take ...
11-02-2009 6:42 PM
Anyone feeling helpful...?
Upgraded from standard BT Voyager 210 ADSL router (that I got free with +net contract just over a year ago) to a netgear DG834G v4 wireless router yesterday.
Intall went fine and had both wireless connectivity to laptop and wired connectivity to pc .... but today PC (Dell Dimension 8300) is taking approx twenty minutes to boot after initially stating that there is a IP address conflict.... after twenty minutes though I'm able to connect both PC and laptop
Have checked all cables and re-installed etc.. done everything that's obvious to me, but problem persists...
Any thoughts/ ideas on what might be causing PC (which was working totally fine withBT router) to take so long, as going through this ritual every day will soon drive me mad!!
Thanks!!!
Re: New Netgear Wireless - causing PC boot up to take 20 mins!
11-02-2009 6:58 PM
11-02-2009 7:31 PM
right click the two computers icon in the task bar(bottom right of screen) and click network and sharing.
on the left of this menu click manage network connection.
on this screen you should see local lan and wireless(on the wired desktop will only be local lan) right click the device in use on that computer and select propites.
right click the internet protocal version 4 and propites
make sure the dns and ip is on obatain auto and click apply. a reboot may be required but not sure
11-02-2009 7:52 PM
still on xp i'm afraid...
mister w, not sure how to set to 'obtain an IP address automatically' via DHCP - have had a root around in properties and (tcp/ip) and 'obtain an ip address automatically' is already selected... is this right?
Thanks for your help - much appreciated..
11-02-2009 7:59 PM
Could there be something else happening which is not related but, coincidently, started at the same time?
Forum Moderator and Customer
11-02-2009 8:04 PM
Quote n properties and (tcp/ip) and 'obtain an ip address automatically' is already selected... is this right?
Yep , thats right.
You can check the IP address thats being allocated by opening a cmd window and running ipconfig.
11-02-2009 8:23 PM
To do this log onto the router admin page and click Router Status. Halfway down you should see 'DHCP' which should say ON.
11-02-2009 10:06 PM
Quote from: robertbeavan still on xp i'm afraid...
Yes that's right.
Another thing you might want to try, is specifically specifying the local IP address yourself on each of the machines. Take a look at each of the TCP/IP configurations below. Use one for your laptop and one for your desktop and see if you have any more luck...
