New Linksys router
mvdm
New Linksys router
My normal Plusnet router started to struggle a bit with all the network traffic in my house, so I upgraded to a Linksys WRT3200ACM. I've logged into the new router, switched it to PPPoE, entered (myusername)@plusdsl.net as the username, but for some reason it still doesn't want to connect.
Are there any other settings I need to be aware of? (FWIW - I have a Static IP on my Plusnet account)
Thanks for your help, it's much appreciated.
Fixes: 213
Re: New Linksys router
We've seen attempts to connect with a incorrect password.
Are you entering the account password?
 Matthew Wheeler
mvdm
No - is this the same password I use for logging into the Plusnet Member Centre?
Fixes: 213
Yes that's also your connection password.
 Matthew Wheeler
mvdm
Thanks - I'll do that this evening! Smiley
Fixes: 213
Let us know how you get on.
 Matthew Wheeler
mvdm
It fully works now - cheers! Smiley
Fixes: 213
Glad to hear it.
 Matthew Wheeler
