New Fibre Install. Went Well, But............
- New Fibre Install. Went Well, But............
27-12-2012 9:36 PM
1. Best Effort Test: -provides background information.
Download Speed
23.55 Mbps
0 Mbps 0 Mbps
Max Achievable Speed
Download speedachieved during the test was - 23.55 Mbps
For your connection, the acceptable range of speeds is 16 Mbps-0 Mbps.
IP Profile for your line is - 23.98 Mbps
Upload Speed
4.53 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 4.53Mbps
Additional Information:
Re: New Fibre Install. Went Well, But............
27-12-2012 10:16 PM
Estimated line speed:
47Mb (Accurate to within +/- 1Mbit) - Checked on 2012-12-08 12:43:07
Current line speed:
78 Mb
28-12-2012 12:00 AM
I'd try a single switch-off of computer, router and modem for a couple of minutes in the morning. Then modem and computer back on, wait for the DSL light to go solid green, then router on. As in the PN instructions, it could be up to 15 minutes before it all then works smoothly.
If things are still as poor then, the install didn't "Went well". Ticket time.
28-12-2012 12:03 AM
28-12-2012 9:39 AM
Download Speed
25.19 Mbps
0 Mbps 0 Mbps
Download speedachieved during the test was - 25.19 Mbps
IP Profile for your line is - 25.81 Mbps
Upload Speed
4.43 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 4.43Mbps
Appreciate all your help.
28-12-2012 9:59 AM
28-12-2012 10:10 AM
28-12-2012 10:21 AM
[Edit] This is a rather old graph:
http://www.buckconsult.co.uk/fttx/graphvdsl2.png
28-12-2012 10:38 AM
I've checked your line and the speeds you are seeing is the modem is currently syncing at.
Everything is set correct on your account to achieve higher speeds, so I'd advise going through our <a href="http://faults.plus.net">faults checker</a> so we can look into this further.
28-12-2012 10:53 AM
28-12-2012 11:04 AM
28-12-2012 11:11 AM
01-01-2013 4:20 PM
02-01-2013 6:08 PM
02-01-2013 6:16 PM
This thread might give you food for thought or prompt a comment or suggestion of your own: http://community.plus.net/forum/index.php/topic,109930.msg941545.html#msg941545
