New Fibre Install Slow
- Re: New Fibre Install Slow
23-05-2014 6:46 PM
I have had fibre installed today over my previous broadband only Plusnet connection.
Initial speed tests thru wireless on the ipad show only 1.5mbps, which is up barely .5 on previous and thru Ethernet other computer download speeds are pretty much maxing out on the same level although uploads are much faster.
Will this improve over the next few days as the line is adjusted or is this it?
Mark
Mark
Message 1 of 9
(1,180 Views)
8 REPLIES 8
23-05-2014 7:04 PM
what does the line speed say here https://portal.plus.net/my.html?action=data_transfer_speed
it might be that it hasn't updated to your new speeds yet. you can look here http://speedtest.btwholesale.com/ under further diagnostics for what it should be.
if they are different a call PN will sort it out for you.
Message 2 of 9
(716 Views)
24-05-2014 8:32 AM
The first link says my line speed is set at 1.8mb
Message 3 of 9
(716 Views)
24-05-2014 10:27 AM
That's your issue, unless there is a major problem.
Message 4 of 9
(716 Views)
24-05-2014 10:28 AM
Is your upload speed much improved?
Message 5 of 9
(716 Views)
24-05-2014 10:45 AM
Yes the upload speed is really fast
Message 6 of 9
(716 Views)
24-05-2014 10:46 AM
give them a call to ask for the Plusnet profile to be updated
Message 7 of 9
(716 Views)
24-05-2014 3:13 PM
Thanks very much for your help folks... After the standard 30 minute wait time on the phone they were able to sort it out there and then.
Thanks again... Great customer service
Message 8 of 9
(716 Views)
24-05-2014 3:26 PM
Glad it's sorted for you
Message 9 of 9
(716 Views)
