New Fibre Connection and Speed
- Re: New Fibre Connection and Speed
16-07-2013 6:14 PM
Hey guys,
quick question (hopefully!) my new fibre connection went live yesterday without a hitch, many thanks to the plus net guys for their excellent co-ordination. I have been using it without issue and have been testing the speed. I am aware the speed may fluctuate somewhat while the line adjusts but how long before I should expect to see the final speed?
It's been a little over 24 hours now and I'm seeing download speeds of about 20-30mb and upload about 20mb. Estimated it was about 70-80mb down. Am I likely to achieve that? is what I am seeing now the final speed? Can it be manually adjusted somehow?
Thanks in advance.
Thanks in advance.
Message 1 of 2
(512 Views)
1 REPLY 1
17-07-2013 8:39 AM
Hi ellrocko,
I've checked over your connection and you should be seeing higher download speeds, are you currently connecting over a wired or wireless connection?
Message 2 of 2
(241 Views)
