New Fibre Broadband Speeds?
Fixes: 334
Re: New Fibre Broadband Speeds?
So, are you going to provide the details I requested? If the phone works, then do all the tests/supply the information and we will try to help. Otherwise, say you don't need the help, and I, at least, will ignore this topic.
joecool
Hi thx for your help will do what you said but going to telephone with details.
Appreciated
MatthewWheeler
Fixes: 503
Hi @joecool
I'm sorry to hear that your speeds have dropped that certainly shouldn't have happened!
After testing your line I've seen a potential internal issue known as a bridge tap which could be due to the way you've got things setup.
Are you able to provide any photos of how you have things connected?
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
joecool
Hi thx for your reply
Not had this before, I will remove my unused telephone lines now I am disconnected. Restarted hub & still speeds 26.58 & 8.72
Fixes: 334
Could you actually answer a post - like @MatthewWheeler 's above, which asked for pictures of your setup, or mine further up which asked for data in an attempt to try and help you?
joecool
Hi sorry about that a few problems uploading. Hub Tech Log. There's an extension from master socket to bedroom to study. Appreciate any help as speeds still the same. Thx
Fixes: 530
@joecool that will be whats causing the bridge tap report. Try removing the extension plug and connecting the router directly to the master socket, then check the data rate on the helpdesk page of the hub
Fixes: 459
@joecool
The best way to eliminate any internal bridge taps is to remove the faceplate from the BT master socket (you may need to remove two screws). In the back section you will find the test socket. Plug a filter in the test socket and use this to connect the hub.
joecool
OK thx to both will check. With other contracts no problems with speed.
Fixes: 334
Based on that extremely difficult to read Help desk shot, I personally think there is more going off - low DSL uptime, high D/S SNR margin both lead me to suspect outside problems, although the xDSL uptime could be a red herring if the OP has benn swapping cables/disconnecting.
Fixes: 530
high D/S SNR margin
That's almost certainly due to the unfiltered extension.
joecool
Hi hub shot is clear just when uploaded?
joecool
Hi thx again all for your help, speeds of 44.56 mbps (12 days since activation)
