New Fibre Broadband Speeds?
joecool
Hi new Fibre broadband only package was activated on Monday. Expected download speeds between 45 & 65 mbs. Fibre average 50mbs. Minimum guaranteed 35mbs. At the moment receiving between 20 & 26 mbs. Will this improve over the next few days & when the actual landline is disconnected as it still seems connected?
Appreciate any help pls
Thx
27 REPLIES 27
Fixes: 334
Re: New Fibre Broadband Speeds?
@joecool That current speed looks a little low to me. Can you post the result of https://speedtest.btwholesale.com/ , and your Hubs Technical Log - assuming you are using a Hub2?
joecool
Hi thx for quick reply
I had tried BT speedtest but site doesn't open properly. Other speedtests show 21-22 mbs & 8 -9 mbs. Still using Hub 1 told it still should be OK
Fixes: 334
Strange about the BT site - I've not heard that before - are you using a desktop/laptop or a mobile device?
Try https://www.speedtest.net/ - and please post the result.
If you are using the Hub1 - which is perfectly fine, BTW - can you post the 'help Desk' page - obscuring personal details?
joecool
Hi speedtest result shows 20.95 maps.
Help desk page?
@joecool  were you on ADSL previously ?
Fixes: 334
A picture paints a thousand words, but basically : log into the hub and then navigate to:
joecool
Unlimited Fibre with speeds up to 36-38 mbps
Edit - post deleted
joecool
Hi seems that the reason getting blank screen is msg says 'Sorry, The speed test is no longer available on the web' moved to My BT App
joecool
Appreciate your help Will get back later
Fixes: 334
That is a very strange one - I have zero problems accessing and running it on my laptop.
joecool
Hi BT Speed test working this morning, speeds show 27.13 mbps & 8.52 mbps
Fixes: 334
Still a bit low - IMO
Please follow the below, and maybe a Community member can suggest what needs looking at.
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
joecool
Hi thx again its fibre broadband only so landline is supposed to be disconnected but still appears connected.
