New FTTC low dowload speed
- Re: New FTTP low dowload speed
15-02-2013 8:04 PM
First post so please excuse any noob mistakes!
I know that I should be patient and let things settle down, but is there a problem with my new FTTC install done yesterday?
From the BTW speed test I'm getting
Down 16.08Mb
Up 13.42Mb
Ping latency 36.38
I've repeated the test several times, and I get the same figures plus/minus 1.00 using my TP-Link WR1043nd router and direct through the modem.
I notice that the Plusnet estimated line speed is 69Mb (on 21/01/2013) with current line speed 17Mb. And BTW I'm about 250 metres from the cabinet.
When the engineer had completed the install he showed me his test result that implied a download of 80, (ie 80/20) , and I think the SNR was about 3.4, (but don't rely on that)
Any ideas please
David
Edit 15/02/2013 @ 23:20 FTTP corrected to FTTC.
Down 16.08Mb
Up 13.42Mb
Ping latency 36.38
Any ideas please
David
Message 1 of 8
(1,468 Views)
7 REPLIES 7
15-02-2013 9:54 PM
It looks like you've still got the profile from ADSL, which should change automatically, eventually, if you call support they should be able to reset it quicker.
Message 2 of 8
(585 Views)
15-02-2013 10:29 PM
This seems more like FTTC (i.e. a normal copper phone line between your house and the cabinet) than FTTP (fibre-optic connection all the way between your house and the exchange)
Message 3 of 8
(585 Views)
15-02-2013 11:17 PM
Yes, sorry, brain not in gear! FTTC of course.
David
David
Message 4 of 8
(585 Views)
Re: New FTTC low dowload speed
16-02-2013 11:02 AM
Raised a question, 65964782
David
David
Message 5 of 8
(585 Views)
18-02-2013 11:24 AM
Message 6 of 8
(585 Views)
18-02-2013 3:23 PM
Adam
Thanks for getting in touch. Yes, it seems to be OK at the moment, getting 70+Mb downstream. I'll check every so often over the next ten days and shout if the connection deteriorates.
David
David
Message 7 of 8
(585 Views)
18-02-2013 4:03 PM
You'll be fine.......mine was the same but after a simple profile reset its been super-fast ever since.
Message 8 of 8
(585 Views)
