New FTTC install, slow speeds
- New FTTC install, slow speeds
- « Previous
- 1
- 2
- Next »
Re: New FTTC install, slow speeds
09-05-2014 9:32 AM
09-05-2014 4:54 PM
Ill try a factory reset (not that I've changed anything anyway)
http://www.thinkbroadband.com/ping/share/b7549d561c2edd9ea82aaf911d59b4a5-08-05-2014.html
09-05-2014 9:59 PM
I just get timeout errors when I try to open 192.168.1.254.
Tried reboots and no change.
I cant even get in to re-enable the ping response for the TBB graphs.
But as you can see I am still connected and seems connection wise.
Is this equipment supposed to be reliable?
11-05-2014 6:06 PM
http://www.thinkbroadband.com/ping/share/f0956849fb1e18dcf3d6706545e9d1a7-10-05-2014.html
Do I need to get a new router?
12-05-2014 11:45 AM
I've just looked over the line and it appears that the modem hasn't seen any disconnects recently, however, the router does appear to have disconnected on a few occasions.
To rule the router out being at fault, I've sent you a replacement. Can you let us know how you get on with that?
19-05-2014 7:00 PM
Same problems im afraid. Crashes at 9pm last night and approx 8.45 this morning. Seems to be about 3-4 per day at least.
New router using new PSU, different plug socket, even got the router dangling in the air to make sure its not overheating!
Logs confirm that the router is crashing.
Is this usual for this router? Can you send a different brand?
20-05-2014 10:16 AM
I'm just wondering if you made a call on that a bit quickly.
The connection looks stable from our point of view and the profile is set appropriately:
img src="http://community.plus.net/visualradius/generated/image14005772444888.png"/>
Quote Logs confirm that the router is crashing.
Apart from the logs showing that, what happens from your point of view when it crashes?
We don't have any other types of fibre router we could send, perhaps a factory reset on the new one might be a good idea.
20-05-2014 3:38 PM
The DSL is not dropping, just the PPP session. You should be able to see it in your logs.
Ive tried factory restarts and defaults etc, infact the settings on the router are all default anyway (only your automatic scripts setting user/pass, and I have enabled the ping response).
I think its a limitation of the device itself.
20-05-2014 4:11 PM
<img src="http://community.plus.net/visualradius/generated/image14005985852165.png"/>
I've looked on our suppliers systems and can't see any drops that aren't on the graph either
Do you have another router you can try? Perhaps a different model?
20-05-2014 4:46 PM
Ill have a look around and see what's available.
21-05-2014 4:41 PM
21-05-2014 5:03 PM
23-05-2014 2:48 PM
Quote from: Chris Your Fault Ticket is being worked on at the moment. Dan will be in touch very shortly.
Not heard a peep!
23-05-2014 3:00 PM
Can you reply back to the ticket if you're continuing to have problems?
23-05-2014 5:44 PM
I also didnt get any notification of Dans reply, ill check now.
- « Previous
- 1
- 2
- Next »
