New FTTC install - Current Line Speed update, please.
- New FTTC install - Current Line Speed update, plea...
28-05-2014 3:11 PM
Long story short - he changed my faceplate, plugged in the modem and then tried for about half an hour to get a line test on his tablet - 15th time was the charm.
I'm the first on our cabinet, and connected currently with the Home Hub 5 as I couldn't get the TP-Link connected to the modem using the WAN port. I'll come back to that later...
BTW Speedtest result:
Quote 1. Best Effort Test:
Download Speed : 11.12 Mbps
2. Upstream Test:
Upload Speed : 13.17 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
My line stats:
Quote 4. Board version: BT Hub 5A
5. VDSL uptime: 0 days, 00:10:45
6. Data rate: 16690 / 68292
7. Maximum data rate: 16750 / 68466
8. Noise margin: 5.8 / 6.1
9. Line attenuation: 0.0 / 21.5
10. Signal attenuation: 0.0 / 20.5
Happy with the line speed as estimate was 69 Mb/sec down, however my Current Line Speed has been left at the ADSL level and needs to be updated.
Quote Estimated line speed:
69Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.)
- Checked on 2014-05-03 02:03:00
Current line speed:
11.8 Mb
The Hub 5 is being retired unless I can't get the TP-Link working - it's already rebooted itself twice since I started on this post...
Re: New FTTC install - Current Line Speed update, please.
28-05-2014 3:48 PM
Glad to see your install is all sorted, I've just updated your profile for you so hopefully now you'll see the benefits!
28-05-2014 4:01 PM
2. Upstream Test:
Upload Speed : 11.62 Mbps
28-05-2014 4:04 PM
28-05-2014 4:51 PM
Because the HH5 doesn't respond to pings, of course my BQM has stopped working. I'd like to get the TP-Link N600 TD-W8980 working with the VDSL modem - does anyone have one of these successfully connected to a VDSL modem, and if so, how did you do it?
28-05-2014 7:49 PM
Couldn't figure out the TP-Link WAN connection, so went out and bought a TL-WDR3600 instead - stable so far, after just a few minutes connected, but I suspect all this faffing around and router rebooting may have affected the DLM, but we'll let it settle down before trying anything else.
(ETA Speedtest graphic not working, so ran another one)
29-05-2014 1:22 PM
Current line speed: 11.8 Mb
So now the BTW speed test shows the following:
Results Image not loaded
1. Best Effort Test: -provides background information.
Download Speed 11.54 Mbps
0 Mbps 65.38 Mbps Max Achievable Speed
Download speed achieved during the test was - 11.54 Mbps
For your connection, the acceptable range of speeds is 52.3 Mbps-65.38 Mbps.
Additional Information: IP Profile for your line is - 65.38 Mbps
Upload Speed 14.31 Mbps
0 Mbps 20 Mbps Max Achievable Speed
Upload speed achieved during the test was - 14.31Mbps
Additional Information: Upstream Rate IP profile on your line is - 20 Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
TAP3 test failed to display the page after connecting with speedtest@speedtest_domain - see attached graphic from early this morning (or late last night if you prefer)
Can the Current Line Speed be reset, please?
29-05-2014 3:38 PM
29-05-2014 3:54 PM
29-05-2014 10:14 PM
30-05-2014 1:08 AM
Hah! Having said that, I'm now getting this on Further Diagnostics:
Quote Test Error
The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.
I'll try again
