New FTTC customer current speed query.
- New FTTC customer current speed query.
18-05-2013 11:32 AM
Hi
I joined Plusnet yesterday with FTTC. My estimate was 51mb down and 13mb up. I'm currently getting around 48 mbit down and 17 up. In the control panel it says current speed s 78mb?
What am I connected at? I can't see the stats on the ECI modem. If it is 78mb how do I get the extra speed?
Dave
Dave
Message 1 of 4
(692 Views)
3 REPLIES 3
Re: New FTTC customer current speed query.
18-05-2013 11:49 AM
If you run the BT Wholesale speed test: http://speedtest.btwholesale.com/ then select 'further diagnostics' you will get (amongst other things) your BT IP Profile, this is set at around 97% of your sync speed.
The Plusnet Current Line Speed should match this figure (rounded down slightly) but it takes time to update. 78 is the initial setting for new fibre connections (on 'up to 80Mb/s').
Call me 'w23'
Message 2 of 4
(403 Views)
18-05-2013 12:10 PM
Ah OK thanks. That says: IP Profile for your line is - 50.44 Mbps. I guess hopes of a higher speed are dashed in a flash.
Message 3 of 4
(403 Views)
18-05-2013 12:13 PM
Yes. Looks like the estimate was spot on.
Message 4 of 4
(403 Views)
