New FTTC Install - Possible Wrong IP Profile?
- Re: New FTTC Install - Possible Wrong IP Profile?
05-08-2014 1:09 PM
We signed up to plusnet's 80/20 and our expected down speed was 54Mbps our up speed I think is pretty low (Don't really know what to expect)
According to http://speedtest.btwholesale.com/ we are currently getting.
__________________
Download speedachieved during the test was - 38.6 Mbps
For your connection, the acceptable range of speedsis 31.81 Mbps-39.76 Mbps .
Additional Information:
IP Profile for your line is - 39.76 Mbps
__________________
Upload speed achieved during the test was - 5.28Mbps
__________________
Could we be stuck on the wrong IP Profile? As I understand it we should be on 80/20?
__________________
__________________
__________________
Message 1 of 9
(1,737 Views)
8 REPLIES 8
05-08-2014 1:15 PM
that indicates that your sync speed is about 41Mbps so it looks as though you are provisioned correctly
Message 2 of 9
(1,085 Views)
05-08-2014 1:50 PM
Forgive me if I am wrong but as we have an estimated 54Mbps and our product is Unlimited Fibre Extra 80/20 shouldn't our IP Profile be higher than the current 39.76 Mbps?
Message 3 of 9
(1,085 Views)
05-08-2014 1:58 PM
Not really
The IP profile is calculated from the actual sync rate and all it means was that the estimate was a bit wrong
There could be many reasons for that
If you put your phone number in here was does it say https://www.dslchecker.bt.com/
It should give two options for estimated speed depending on the quality of the wiring between the fibre cab and your modem
Message 4 of 9
(1,085 Views)
05-08-2014 2:03 PM
I can not get any details from that url as it's a plusnet line But I have already completed a few checks myself using the address and postcode checker which are below.
FTTC Range A (Clean) 69.5 52.5 20 14.9 -- Available
FTTC Range B (Impacted) 60 35 20 10 -- Available
Also if it helps, A little digging around my plusnet account shows me these details.
Postcode:
Phone exchange:
SOUTH ELMSALL
Estimated line speed:
52Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2014-07-01 14:26:47
Current line speed:
78 Mb
All the speed testes in the world are showing a solid 38Mbps /5-6Mbps So I am a little worried we are stuck on a slower /lower profile!
Postcode:
Phone exchange:
SOUTH ELMSALL
Current line speed:
78 Mb
Message 5 of 9
(1,085 Views)
05-08-2014 2:26 PM
Hi hollylizy,
I've just checked both the profile on our side as well as the profile set on the suppliers side and everything seems to match up.
The details of the estimated speeds you provided below show both a clean and an impacted range and you seem to be able to obtain speeds just above the lowest estimate on an impacted line which would sit within the acceptable limits. The testing done earlier to check the profiles doesn't seem to have picked up any fault issues either.
Given the above, this may well be the highest speed that your line can manage with the current technology. If this doesn't change over the course of the next week I would be inclined to move the service onto the standard 40/20 Fibre Unlimited package if you're unable to receive any speeds that give you a significant benefit over the 39mbps you're seeing now.
Quote from: hollylizy FTTC Range A (Clean) 69.5 52.5 20 14.9 -- Available
Message 6 of 9
(1,083 Views)
05-08-2014 3:59 PM
Thank you for looking into it for me
It only worried me because I get a pretty solid 38/39Mbps so I thought it might have been at the end of the lower profile There really are no problems what so ever and I am happy to leave everything exactly where it is while the going is good!
I am just relieved to know everything is where it should be, Thank you again for your help...
Message 7 of 9
(1,083 Views)
05-08-2014 4:08 PM
Quote from: Adam Given the above, this may well be the highest speed that your line can manage with the current technology. If this doesn't change over the course of the next week I would be inclined to move the service onto the standard 40/20 Fibre Unlimited package if you're unable to receive any speeds that give you a significant benefit over the 39mbps you're seeing now.
That was an option?! When I had the same issue has hollylizy a long time ago I was pretty much out of luck.
https://community.plus.net/forum/index.php/topic,118226.msg1023089.html#msg1023089
Message 8 of 9
(1,083 Views)
05-08-2014 4:16 PM
That is because 40/20 unlimited wasn't introduced until June this year
Message 9 of 9
(1,083 Views)
