New FTTC Disconnections
cbb
I've had my new FTTC a week now and it's great when it works, but I'm getting quite a few disconnections which have become more frequent today. Should the DLM cause my speed to drop if I get frequent disconnections, because this hasn't happened. I've run the BT Wholesale further diagnostics and my profile is still at 77.44 Mbps. Can someone from Plusnet advise please.
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: New FTTC Disconnections
Hi cbb,
I've just run a quick check on your line but can't see anything obvious that might be causing the drops (from a remote stand point). I think it'd be worth having our faults team take a look over things as there are a fair number of drops
<img src="http://community.plus.net/visualradius/generated/image13835751796164.png"/>
You can raise a fault at http://faults.plus.net so we can get a more in depth look at your line.
Chris Pettitt
Cloud Environments Engineer
cbb
OK, thank you. I'll do that.
cbb
Well, I thought I'd cured this, I rebooted everything ant it ran perfectly for well over a day, but then failed again last night. Now I can't connect at all, I'm getting "Concentrator not reachable" from the router. what does this mean? The modem is synced ok. Anyway I've raised a ticket so I suppose I shall just have to wait now.
I don't seem to be having a very good start to Plusnet. Fortunately I haven't cancelled my virgin cable broadband yet so I'm using that at the moment. Virgin is far from perfect but I very rarely has complete disconnections. I hope this isn't going to be a regular occurence.
Plusnet Staff
Plusnet Staff
Fixes: 5
If there is a fault with the service - we'll ensure this gets fixed for you.
If you could leave your router for 2-3 minutes and try and re-connect again, that should clear the Concentrator not reachable issue.
Chris Pettitt
cbb
No I've tried leaving the router, I've tried turning it off and leaving it. Whatever I do now I get "Concentrator not reachable"  Direct connection from computer to modem doesn't work either.
Plusnet Staff
Plusnet Staff
Fixes: 5
Can you please power down your Modem and Router for 15 minutes and try to reconnect.
Chris Pettitt
cbb
I had already tried that but I've just tried it again. The router just stays stuck on "connecting". I think the concentrator messeage may have been because as it wasn't connecting I was clicking "disconnect" and then "connect" again straight away. That's when I get the concentrator message. Anyway it still won't connect.
Plusnet Staff
Plusnet Staff
Fixes: 5
I can see that the fault has been raised with our suppliers for further investigation.
The Concentrator not reachable should have resolved itself following my previous advice, if it hasn't I would await a further update from our faults team on this.
Chris Pettitt
cbb
Yes I think the concentrator message was me trying to reconnect too quickly. I will bear that in mind for the future. I will wait and see what happens now then. Thanks for your help.
