New Customer Very Slow Speeds
- New Customer Very Slow Speeds
27-04-2010 7:00 PM
Re: New Customer Very Slow Speeds
27-04-2010 7:06 PM
27-04-2010 7:50 PM
2. Could you post the stats (sync speed, attenuation and noise margin) reported by your router please.
27-04-2010 8:09 PM
im not sure if that answers your question
2) Uptime: 6 days, 22:51:59
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,312
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 35.00
Output Power (Up/Down) [dBm]: 12.0 / 17.5
Line Attenuation (Up/Down) [dB]: 22.5 / 40.0
SN Margin (Up/Down) [dB]: 18.0 / 20.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 1 / 0
FEC Errors (Up/Down): 35 / 117,878,415
CRC Errors (Up/Down): 35 / 1,057,949
HEC Errors (Up/Down): 21 / 607,455
27-04-2010 8:19 PM
Also the SN Margin is very high which will be severely restricting your speed. Something is definitely not right either internally or between you and the exchange.
Can you connect your router to the test socket inside the master socket without any phone and post those stats again please.
27-04-2010 8:25 PM
27-04-2010 8:34 PM
27-04-2010 8:35 PM
27-04-2010 8:52 PM
its now gone up to 2.495mb download upload is still 448k though,
i looked behind the face of the phone socket again, what i have is like that photo from the other side of the chip board and my line in (always was) connected into that middle connector.
the changes made were
Unplugging phone
unplugging sky boxes (2)
Reboot router
Strange thing is when i had internet with sky the set up was the same as when i had 1300kb with you, which makes no sense?
27-04-2010 8:54 PM
Quote from: itsme What you believe is the master socket has it a yellow capacitor fitted?
[/quote
i saw the board from the other side, it appears to be fixed to the socket, however i doubt there was enough clearance between the plastic cover and back of the board for a capacitor
27-04-2010 8:59 PM
Can you post the router stats again please.
27-04-2010 9:11 PM
Or better still do not have them connected at all to phone line.
27-04-2010 9:11 PM
here are the new stats
Uptime: 0 days, 0:05:59
Bandwidth (Up/Down) [kbps/kbps]: 448 / 2,560
SN Margin (Up/Down) [dB]: 19.0 / 17.0
FEC Errors (Up/Down): 0 / 344
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
Again im confused as to how i achieved similar speeds to now with sky while using the previous setup with no filter to the sky boxes
Any ides on the upload speed?
By the way you have been much more helpful than the helpdesk i am very grateful
27-04-2010 9:19 PM
Now you've filtered the Sky boxes, you should see speeds increase further over the next few weeks, leave your router connected all the time so that the exchange sees it as being really stable. Reconnecting once per day between 10am and 3 or 4 pm should help encourage it to improve.
(Incidentally, if you'd been wired up properly you might have seen faster speeds on Sky)
27-04-2010 9:26 PM
thanks for your help
is plusnet offering a llu package in the future/ am i on it now?
