New Customer: From 37mbit to 8mbit
- Re: New Customer: From 37mbit to 8mbit
09-10-2013 8:33 PM
I have experienced a flawless service until today... 😛
PlusNet-
Estimated line speed:
21Mb
Current line speed:
37 Mb
I usually get 36.9Mb in real world downloads!
Download: 36.9Mb
Upload: 7.2Mb
My router and wireless hub are all located downstairs directly connected to the phone line.
I decided to move the route/hub upstairs so that I would not have to use wireless. I used an extension cable for the DSL line.
Upstairs Extension Cable Setup-
Download: 21Mb
Upload: 5Mb
^This was slower than Wifi so I decided to move the router/hub back downstairs, and directly into the telephone line.
Now here's my current wired speed:
Download: 9.36 Mb
IP Profile for your line is - 38.72Mb
So, my speed has reduced from 37Mb to 9Mb. I have returned everything to the same set up I was using before, yet no speed change.
Also, is PlusNet throttling me to 38.72 Mb? As I'm hitting this speed on downloads I would like this limit removed or moved higher if possible.
PlusNet-
21Mb
Current line speed:
37 Mb
Download: 36.9Mb
Upload: 7.2Mb
Download: 21Mb
Upload: 5Mb
Download: 9.36 Mb
Message 1 of 5
(955 Views)
4 REPLIES 4
10-10-2013 10:15 AM
There's no obvious issue looking at your line and settings.
Are you able to try a PPPoE connection?
Once we get your speeds sorted we can look at changing you to the 80/20 product to see if this helps.
Message 2 of 5
(424 Views)
13-10-2013 12:16 AM
The speed issue sorted itself. It fixed itself and raised the sync speed back to 38mb after one hour or so.
Would it be possible to try the 80/20 profile?
I'm currently hitting the limit of 38-39Mb when connected on a wired connection.
Adie:quote
Adie:quote
Message 3 of 5
(424 Views)
13-10-2013 11:22 AM
You'd have done far better to leave the modem connected to the master socket and then a long Ethernet cable to the router upstairs. That arrangement would guarantee no loss of speed unless the Ethernet cable was more than 100 metres long.
Message 4 of 5
(424 Views)
14-10-2013 7:30 AM
Yes, I ordered a 30 meter Ethernet cable from amazon a few days ago. This is my plan
Added the long ethernet cable:
Quote from: jelv You'd have done far better to leave the modem connected to the master socket.
Message 5 of 5
(424 Views)
