New Customer, Fastpath request + Uncap upload
- New Customer, Fastpath request + Uncap upload
Re: New Customer, Fastpath request + Uncap upload
31-10-2013 4:21 PM
It should affect you (other than a slight increase in ping/latency) on 20CN and 21CN.
31-10-2013 4:28 PM
Same providers on fastpath, B t = Constant 31. talk talk 22, sky 29-35 and virgin was 19-22ms.
31-10-2013 4:59 PM
I'm currently writing some documentation surrounding this which should be available at some point next week, it should help explain how Interleaving works and how it might affect your connection
31-10-2013 5:15 PM
31-10-2013 5:16 PM
31-10-2013 5:24 PM
31-10-2013 5:26 PM
Quote from: Chris
It's impossible for me to say what ping rates you are going to get, however, I would guess that your pings will be low if you are relatively close to your Local Exchange (If you're estimated good speeds, you are likely near the exchange).
As I mentioned earlier, I can't really advise what sort of ping times you would get without having the connection up and running you being able to have a look at the ping times you get.
31-10-2013 5:29 PM
Quote from: MickHowes1 do you roughly know what ur ping is on interleaved?
Here's my thinkbroadband Broadband Quality Monitor for the day interleaving was turned off:
(Click graph for full size version)
31-10-2013 5:31 PM
and also chris has ping got anything to do with the SNR ? and if so can i have tht to the best setting for lower ping....
01-11-2013 9:41 AM
01-11-2013 10:39 AM
01-11-2013 12:33 PM
01-11-2013 12:34 PM
01-11-2013 1:27 PM
Just checked the order for you and it's showing as completed so I've activated your account for you - you should be fine to connect now
01-11-2013 1:56 PM
