New Customer, Can't get Online
- New Customer, Can't get Online
17-02-2011 12:53 PM
I'm trying to set up a friends broadband but i'm getting no joy.
They went 'live' on Tuesday - got confirmation via e-mail but i spent an hour yesterday trying to set it up but failed.
I have followed the guide on here and in the booklet.
I think the issue is to do with the Router Internet light now staying on - sometimes it flashes then off then on then red and so on, pretty frustrating.
They did have the phone connected via an extension lead so i got rid of that and tried directly into the master socket using a filter then turned router on then laptop but it still won't connect.
I have logged into the router webpage and hit connect but afterwards it comes up with a Authentication Failed.
I have tried various things to get it to work but getting no where fast.
Anyone have any ideas?
Thanks.
Re: New Customer, Can't get Online
17-02-2011 12:59 PM
Ex-Broadband Service Manager
17-02-2011 1:06 PM
17-02-2011 1:07 PM
17-02-2011 1:08 PM
Thanks for the speedy reply.
Nope, just connected the Router and turned it on. I entered the username/password as down on the sticky label.
17-02-2011 1:08 PM
Interesting that I'm seeing errors on your account though Rodney!?
17-02-2011 1:11 PM
I really doubt that Plusnet issue routers with the username and password on a sticky label are you sure that isn't the username and password for accessing the router
The username and password would have been set up during the ordering process
17-02-2011 1:16 PM
17-02-2011 1:19 PM
Quote from: Kelly Good question Jim!
I can't answer that one! i did try quite a few passwords that we had wrote down to try and get online so maybe that's why.
Here's a few pics i took whilst trying, thought maybe they could explain it better perhaps
17-02-2011 1:24 PM
Quote from: Oldjim Regarding the info on the sticky label.
Yeah sorry i used that info to access the router page just to make it clear.
I have a bunch of passwords/usernames jotted down - one for webmail/forum etc etc i'm wondering if i put the right one in but i've tried them all!!
Kelly, his username is ianlees1.
17-02-2011 1:27 PM
17-02-2011 1:28 PM
Much appreciated, thanks.
dick:quote
17-02-2011 1:34 PM
Just to clarify it looks like there may be some confusion between two sets of login details. The ones listed on the sticker on the router are for the wireless connection between the PC and the router. The page on the bottom left screenshot is where you wanted to be, it looks like the picture you took just cuts off a link on the top right of the screen that says 'configure' that allows you to change the login details.
See if you can get yourself back on that screen and check the password with your friend, if their in doubt or it still doesn't work you'd need to contact our support centre to confirm the details.
Once you've got that sorted let me know if you have any other difficulties.
17-02-2011 1:34 PM
Resetting the router to factory defaults (using the pin-hole button on the back) might be necessary to restart this easy start process.
Some of those images appear to be associated with wireless set up which will require information from the sticky label, in particular the Wireless Key.
17-02-2011 1:39 PM
