New Community Site Skin - Testing/Feedback
- New Community Site Skin - Testing/Feedback
11-01-2008 5:15 PM
Right, as some people may know, we've been working on doing a redesign of the Community Site over the last few months. We've had a final push on it over the last week, and are now able to make it available on our Beta site for people to test.
If you wish to take a look at the skin, then head over to http://community.beta.plus.net/ and you can have a look. (Note that not all the accounts that exist on this site are avilable on the Beta site so you may not be able to sign in).
If you have any comments to make, please append them to this tread.
It's Friday afternoon, and we're all going home for the weekend so we might not respond until Monday though
Colin
Re: New Community Site Skin - Testing/Feedback
11-01-2008 5:21 PM
B.
11-01-2008 5:26 PM
11-01-2008 5:27 PM
Can you please make the basic font on the forum the same as the home page
11-01-2008 5:39 PM
11-01-2008 5:47 PM
The thread view is good with the white / grey definition. But I think there should be some more definition seperating some of the content on the main forum view instead of it being a blank white background.
The same could be said for the calendar view :-
http://community.beta.plus.net/forum/index.php?action=calendar
11-01-2008 5:51 PM
11-01-2008 6:00 PM
A couple of observations:
1) I agree with Liam's comments on the amount of 'White space' in the forums. Too stark on a widescreen monitor.
2) There appears to be something odd in the 'Latest forum posts' section both on the Home page and where it appears on the Blog page. If it's a date it looks wrong? If it's not a date, what is it?
3) The 'Tabs'. Default is Home displayed as White. Click 'Forums', on 'mouse over' goes Orange until new page loaded, then 'Forum' tab turns White. Clicking either 'Blogs' or 'Polls' Mouse over turns Tab Orange, but it goes back to the default colour when the page is loaded.
4) Go to 'Forums' using the Tab and 'Blogs' is replaced with a new Title 'About', so no way to navigate direct from Forums to Blogs?
Maurice
11-01-2008 6:21 PM
File: /local/www/community/forum/Themes/plusnet-new/Login.template.php (main_above sub template - eval?)
Line: 49
The password had been saved.
11-01-2008 6:46 PM
In the index pages of the forum the subject column is narrow and causing a lot of line breaks (I've been trying resizing the browser window to see how it behaves). Some of the other columns look as if they could be reduced (particularly the first two).
When starting a new topic, what is the box under the subject for?
I think you need to limit the length of a display name!
11-01-2008 11:48 PM
http://community.beta.plus.net/forum/index.php/topic,1909.msg469524.html#msg469524
The quoted text has a thick line line to say that it's a quote - but doesn't say who it's quoting.
The .sig has a scrollbar (even though there is no scrollable content in the .sig).
I still think the body font is either a bit small and/or lack of contrast where you have grey on pale blue.
11-01-2008 11:55 PM
Quote I'm not keen on some of the attributes e.g.
That's because the poster didn't include the "author= etc" in the quote. Here's the same post on here:
http://community.plus.net/forum/index.php/topic,1909.msg469524.html#msg469524
12-01-2008 12:05 AM
The Beta post takes about 11cm of vertical space, and only 8 cm on the current version - and the "old" version is also more readable.
12-01-2008 12:43 AM
The other problem with that post (you can see it if you quote it) is that it has a number of blank lines at the end of the post which makes it appear worse. I would have thought stripping trialling blank lines would be a good idea. That applies to this version as well...
12-01-2008 3:31 AM
Quote from: Oldjim Colin.
I agree with you Oldjim.
