New BT Modem...what does the reset button do?
Fixes: 4
BTOR recently replaced mu decaying, 12 months old fibre modem. The new one is producing a much faster D/L & is running much cooler. I've just noticed that this one has a reset button next to the power input socket. Does anyone know what it does?
Yes I know, it resets the modem but what is the purpose of the reset?
VileReynard
Seasoned Pro
Fixes: 10
Re: New BT Modem...what does the reset button do?
Try it,  Grin
deadman2020
It's for when you nobble it Wink
Fixes: 4
I can see that I'll have to wait a while before I get a serious answer!  Roll eyes
rongtw
Fixes: 12
one would presume , its the same as the reset on your router , shutting down the connection & restart  Wink
Fixes: 4
OK, thanks, so the same as recycling the power?
Champnet
If it's a Factory Reset, probably not.............
Fixes: 4
Maybe someone at PN will know the answer?  Undecided
Any model numbers / markings on the modem? (Usually on the bottom).  If we know which one you have you may get a more specific answer.
Call me 'w23'
Fixes: 4
It's an ECI BFOCUS V-2Fub/r. It's about 30% bigger than the old HG612 & has increased my speed by 30%. It also runs at a considerably lower temperature.
