New BT IP profiles.
- New BT IP profiles.
New BT IP profiles.
02-10-2011 3:52 PM
The 585v7 router that Jo-Jo supplied to replace the errant 585v8 router lasted one day. I came down the next morning to find the sitting room smelling strongly of baking printed circuit board, a smell I am familiar with after a working life in electronics. The router was very warm to touch and I wasn't happy with it cooking away directly beneath where we sleep.
Despite all the advice about Belkins and bargepoles I went out and bought a Bellkin F5D8636uk-4A which seems very happy on my line and gives me excellent wireless coverage all around the house. If it has a fault it is that the GUI is a bit lightweight and doesn't report uptime, it also doesn't work with full Routerstats but is OK with Routerstats Lite. As far as I'm aware looking at Routerstats Lite the thing hasn't disconnected except when I've been playing. It runs very cool in it's vertical mounting and looks the part with the blue leds and aerials on the top . Unobtrusive it aint !
oldgeezer
Re: New BT IP profiles.
02-10-2011 6:13 PM
http://community.bt.com/t5/BB-Speed-Connection-Issues/IP-Profile-change-methods/td-p/211701
and on checking bt speed tester my sync has been set at at a random number ending neither 0 or 5 so I presume my 21cn exchange has been moved to the new system.
My SNR has also increased over the weekend not sure if that could be related to the exchange settings being altered as it was previously set by Pn at 3 or 6.
Added
Download speedachieved during the test was - 4404 Kbps
For your connection, the acceptable range of speeds is 2000-7150 Kbps.
Additional Information:
Your DSL Connection Rate :5472 Kbps(DOWN-STREAM), 445 Kbps(UP-STREAM)
IP Profile for your line is - 4827 Kbps
02-10-2011 8:32 PM
03-10-2011 11:45 AM
What does your latest BT speed test report?
Jojo
03-10-2011 12:39 PM
Podman
03-10-2011 2:23 PM
My BT profile is running at 6353 and the strange thing is that my download speed tests from My Broadband Speed and Speedtest.net are both greater than my Plusnet profile and only slightly less than my BT profile at around 6200/6226.
If my line stays stable at that speed I shall be a happy bunny.
oldgeezer
03-10-2011 5:58 PM
attached speed tests before the change I had low snr between 3 and 6 with sync rates allowing 5.5mb 67?? last week, now high SNR and lower speeds.
Any help much appreciated I had the speed thanks to pns hard work a few months ago and now the new system appears to have affected it with a change to SNR.
Attached most recent speed test and previous tests showing speeds before change.
podman
03-10-2011 8:24 PM
podman
all in master socket
04-10-2011 4:32 PM
I've nudged it up to 5000 our end to allow for the new IP profile.
Jojo
04-10-2011 5:53 PM
Many thanks, any chance of a snr reset too please this made fantastic improvement to things before.
Regards,
Podman
04-10-2011 7:47 PM
I'll run a line check tomorrow and see how it's performing and take it from there.
Jojo
04-10-2011 7:50 PM
04-10-2011 9:04 PM
podman
05-10-2011 7:41 AM
05-10-2011 8:54 PM
i have raised a request for the snr rest via a ticket 47362204
regards.
Podman
