New 20CN IP Profile Trial?
sjrinfroyle
Whenever I sync now the IP profile immediately changes to the sync I am at. I am not on a 21CN exchange and the profile is not 88.2% of the sync. Has anybody else seen this?
houlton23
Re: New 20CN IP Profile Trial?
No new profiles here Sad
Can you screenshot your BT Tester results?
Alex Smiley
sjrinfroyle
The profiles are the same but they change immediately after sync.
houlton23
Quote from: sjrinfroyle
I mis-read your post - I thought you meant that the IP Profile matches the sync speed.
And I think (although I can't be certain) that I saw what you mention happen a week ago. Maybe they're testing it out?
Alex Smiley
sjrinfroyle
Perhaps, here are the results anyway:
Download speedachieved during the test was - 3217 Kbps
Additional Information:
Your DSL Connection Rate :7456 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 6500 Kbps
Apprentice
Still the same BT IP Profile xxxx as far as I can see, so will have to wait a while for it to increase to match the new sync rate.  Cry
