Network problems
- Network problems
- « Previous
- 1
- 2
- Next »
Re: Network problems
22-04-2008 10:22 AM
As I read it the redundancy worked:
1. One router acts up (but doesn't fail totally) - we all see funny intermittent problems.
2. Router is isolated meaning we are switched to a secondary path - to us everything appears to be back to normal - but there is now no redundancy and the system is vulnerable to a second failure.
3. Router is fixed and restored to service - redundancy is now back to normal.
Quote The problem seemed to be caused by the CPU in one of our core routers causing OSPF and BGP bounces across the core. The affected router was isolated until this was resolved, and is now back in operation.
Message 16 of 21
(371 Views)
22-04-2008 10:27 AM
Quote from: jelv As I read it the redundancy worked:
Spot on Jelv, thanks
Message 17 of 21
(371 Views)
22-04-2008 10:39 AM
OK, understood this was intermittent and things do not get bad enough to cause the fault detection mechanisms to realise this is a real problem.
SW
SW
3Mb FTTC
3Mb FTTC
Message 18 of 21
(371 Views)
22-04-2008 3:51 PM
Hi all I have just read about this problem would that be why I have been having trouble with my connection it started last week when I kept losing my internet connection and would have to turn router off then on to get it back it happen this morning but has been fine since any ideas
Message 19 of 21
(371 Views)
22-04-2008 4:15 PM
This problem will only have applied to the later hours of last night.
Message 20 of 21
(371 Views)
22-04-2008 8:28 PM
... and tonight, if http://www.plus.net/support/service/problems/problem.php?intProblemId=51255 is anything to go by.
Having followed Bob's link from earlier in the thread, I read it and then took a peek at the new priority problem. There's a striking similarity in the early symptoms.
Message 21 of 21
(371 Views)
- « Previous
- 1
- 2
- Next »
