Network problems
- Network problems
Network problems
21-04-2008 10:58 PM
Just posted this to TBB as I couldnt get access to anything else.
Quote We are currently investigating an intermitent problem which is affecting our portal, the Community site, PUG server and Usertools, including Service status, in addition to some internal network services.
Our networks engineers have been called out and we will provide further information as soon as possible.
We apologise for any inconvenience caused and hope to have this issue resolved as soon as possible.
Cant give any further info just now but we'll provide further detail as we get it.
Re: Network problems
21-04-2008 10:59 PM
21-04-2008 11:03 PM
21-04-2008 11:07 PM
21-04-2008 11:11 PM
Right now, it appears much more stable than it was.
B.
21-04-2008 11:35 PM
I've spent the last half hour painfully executing a broadband fault checker procedure through an intermittent connection. It tells you to make sure that your equipment is turned on and kept connected (yeah, if that was so easy then I wouldn't be doing this, would I??) ... and then I got disconnected.
I get back on and find this thread in the forums which sheds some light on the whole thing. Shame I didn't wait 10 mins before starting the Broadband Fault Confirmer.
21-04-2008 11:38 PM
Tried the support phone number 0845 002 0173 , and got told no faults !!!!!
It's all very well get get information about how good plus is ' from various surveys, but if one cannot get a connect to any of the sites available , and the phone message is no help , why are they getting these congratulations .
( Microsoft site , and others were connecting ???? ? Not sure why ? )
Hiopefully someone will get there act together soon !!!!!!!
21-04-2008 11:43 PM
I've had nasty pings all night and awful connection to the plusnet tools. I'd started debugging my own network to see what was broken, but I don't need to now
-- gyre --
21-04-2008 11:55 PM
22-04-2008 12:03 AM
EDIT: People seem to be reporting problems with Xbox live since todays "maintenance" so my issue is probably more to with that.
I've given up now and I should probably go to bed. Hopefully it'll be OK tomorrow.
22-04-2008 1:01 AM
Adam was about to post in here only to find someone had already done it... once again we look on TBB and you done it again..
Sadly no update at 1am on http://status.plus.net though i am suffering no problems
22-04-2008 1:58 AM
Hi, Hope some1 here has had some experience of my problem tonight....
On "Broadband Your Way Pro"
- Free Over Night speed restriction @ 25 kbps instead of normal 610 kbps !
First time ever i've had peer 2 peer restrictions @ 25kbps @ 1:00 am.
Was fine today @ ~580kbps, but that was in my paid allowance time.
Now @ past 1:30am...my overnight free time is still restricted.
I just hope it's to do with everyone else's problem this night !
22-04-2008 9:44 AM
The service status located here. Reads:
Quote Our network engineers have located the fault and resolved the underlying issue.
All network connectivity is back to normal and we're back to full redundancy also.
A question from a customer on this.
The statement 'we are back to full redundancy' sounds great news ... the question though is what does the redundancy give you when it is clear due to this one failure it caused problems with so many people.
You can only call something redundant when the network will carry on working transparently without that part operating. Clearly when that part broke the network died for many people.
Any reply from PN?
SW.
3Mb FTTC
22-04-2008 9:58 AM
The thing about redundancy is that it usually means you've got backup ready to swing into action when something breaks. With intermittent faults that isn't always obvious.
22-04-2008 10:17 AM
