Network cable query
- Re: Network cable query
Network cable query
03-11-2012 12:05 PM
Hello, I am looking to upgrade the cable which goes between the bt FTTC modem and the Netgear router from the standard one provided.
I have been searching on ebay for a 1m Cat6 ethernet cable but everyone I have come across so far says it's a patch cable.
Will this be ok? I really want the best possible connection I can get and ideally just want a normal ethernet cat6 cable not a patch cable.
Can anyone point me in the right direction?
Message 1 of 6
(1,333 Views)
5 REPLIES 5
03-11-2012 12:14 PM
I don't know the difference - if any - but this is one source http://www.amazon.co.uk/s/ref=nb_sb_ss_i_0_22?url=search-alias%3Dcomputers&field-keywords=cat6+ether...
I suspect there isn't actually a difference except that patch cables can sometimes be crossover cables and that won't work
Message 2 of 6
(583 Views)
03-11-2012 12:27 PM
Can I ask why? Does it need to be longer for example?
If not you're extremely unlikely to achieve anything at all.
It's presumably a 100mbps LAN connection which doesn't require much at all - an old (defunct standard) Cat5 would be fine, even 4-core CW1308 phone cable would work.
(Cat5e is rated up to Gigabit speeds over 100 metres so you don't need anything "better" than that.)
Message 3 of 6
(583 Views)
03-11-2012 2:15 PM
Patch cables are usually made using multistrand wire for flexibility and are wired pin for pin.
Cross over cables as mentioned by Jim have the transmit and receive pairs reversed.
However most if not all Ethernet ports these days are auto-sensing.
Message 4 of 6
(583 Views)
03-11-2012 2:23 PM
Thanks for raising this question rivageeza as it just saved me money. I had assumed (wrongly) that Cat6 was required for gigabit and I am looking to upgrade my network to gigabit.
Has anyone seen my signature, it's gone missing.
Message 5 of 6
(583 Views)
03-11-2012 3:45 PM
Quote from: vultura I had assumed (wrongly) that Cat6 was required for gigabit and I am looking to upgrade my network to gigabit.
I've got plenty of Gigabit kit, e.g. switches and PC's and not a Cat6 cable in sight. Just happily reused normal Cat5e cables.
Message 6 of 6
(583 Views)
