Network Outage?
Network Outage?
Anyone else having problems?
Just been kicked off a few times - traceroutes are failing:
~ Andrew$ traceroute thinkbroadband.com
traceroute to thinkbroadband.com (80.249.99.130), 64 hops max, 52 byte packets
1  192.168.1.1 (192.168.1.1)  0.458 ms  0.304 ms  0.280 ms
2  lo0-central10.ptn-ag02.plus.net (195.166.128.191)  4.825 ms  4.761 ms  10.646 ms
3  * * *
4  * * *
SpendLessTime
Aspiring Hero
Fixes: 63
Re: Network Outage?
Okay here Andy
racing route to thinkbroadband.com [80.249.99.130]
ver a maximum of 30 hops:
1    5 ms    4 ms    4 ms  lo0-central10.pcl-ag01.plus.net [195.166.128.182]
2    4 ms    4 ms    4 ms  link-b-central10.pcl-gw02.plus.net [212.159.2.162]
3    4 ms    4 ms    4 ms  xe-10-0-0.pcl-cr02.plus.net [212.159.0.194]
4    4 ms    4 ms    4 ms  ae1.ptw-cr02.plus.net [195.166.129.2]
5    5 ms    4 ms    4 ms  lonap-gw1.thdo.ncuk.net [5.57.80.142]
6    5 ms    7 ms    6 ms  gi1-24-10-star1.core-rs2.thdo.ncuk.net [80.249.97.9]
7    5 ms    4 ms    5 ms  www.thinkbroadband.com [80.249.99.130]
race complete.
jamesanstee
Re: Network Outage?
I got disconnected about 10 minutes ago though never lost sync just the ip addressed changed.
Re: Network Outage?
Seems to be back again now - other people are reporting the blip on Twitter. Only one graph is showing the same (Jimbof) - http://community.plus.net/ping-graphs/
**Edited: That gateway graph page looked like it was pcl-ag02 but has since corrected itself! **
Fixes: 162
Re: Network Outage?
Service status on the way, we've seen most of those impacted coming back online but if you're having issues still (and can read this thread from an alternative connection)  then you should be able to connect from your router interface.
 Chris Parr
 Plusnet Staff
