Network Issues??
- Network Issues??
Network Issues??
18-06-2008 7:45 PM
Edit. THe RIN connection is also the same. Tried downloading something from microsoft, and speeds are around 250ish rather then the usual 530kbps
Re: Network Issues??
18-06-2008 8:43 PM
18-06-2008 8:49 PM
Whats your dads normal connection speed etc. I very much doubt this is a problem in my setup, as nothing at all has changed. Sync Speed is very stable and consistent. Would welcome any comments from Comms. Even my ping has gone from its usual 60-70 to over 160. Sounds like something is up, surely this is not just general contention. I was on THN-AG3 by the way, and appears there is no packet drop from the current graph, now still using RIN.
18-06-2008 9:09 PM
But yours looks a little like exchange contention. OK, the exchange may not `red` that just means that BT have not acknowledged that there is a problem, and all the systems updated.
Chilly
18-06-2008 9:35 PM
Blackburn Exchange has shown green for ages, but its not beyond possibility that a few VPs are red.
18-06-2008 11:23 PM
I had a 24hr data rate of 1400kbps (BRAS 6500bps),
I don't know what PN did - but a router reboot gave me my speed back.
My exchange is reputably going 21CN in about 2 weeks - coincidence?
19-06-2008 8:19 AM
19-06-2008 11:02 AM
Just after it tells you your profile, it also displays some guff about a Java security error,
it then proceeds to run it's progress bar up to 96%, before freezing.
It always happens to me
19-06-2008 11:27 AM
19-06-2008 2:35 PM
19-06-2008 3:50 PM
Quote from: pierre_pierre well why dont you update your Java?
Well, Java is a real pig. It was a poor cocept and should have been strangled at birth.
Why do BT use it? They should be using some server side scripts to issue their results.
My current Java works on every site but the BT speedtester.
It even works on Java based speedtester sites (except BT).
So why should I put in lots of effort - just so I can run something at weird hours of the day and night.
It tells me the BT BRAS profile [and then crashes] (which frankly is all I need to know).
The PN speedtester works better and much more reliably for actual speed figures.
http://www.javatester.org/version.html says that I am running "Java Version 1.6.0 from Sun Microsystems Inc."
However, since I'm running a 32bit compatibility version (I think!) in a 64 bit browser (and it works), I'm not keen to upgrade unto the 4th decimal place of Java.
PS BT speedtester still falls over if I run a 32 bit Java in a 32 bit browser.
Like I said Java is a pile of [Censored].
[Moderator's note by Jonathan (chillypenguin): Please don't try to avoid the swear filter. Forum Rules ]
19-06-2008 4:09 PM
19-06-2008 4:11 PM
java -version
Quote java version "1.6.0_06"
Java(TM) SE Runtime Environment (build 1.6.0_06-b02)
Java HotSpot(TM) 64-Bit Server VM (build 10.0-b22, mixed mode)
I don't know what all that means, except that the Java platform hasn't stabilized yet.
I think I will wait for Java version 2 to arrive.
19-06-2008 8:07 PM
Noticed another post in the business users complaining of low speed, and the OP reckons Plus have mentioned thats its affected a fair few customers. May not be the same issue, but its worth knowing.
19-06-2008 8:38 PM
Quote from: penfold I have recently noticed alot of lagginess in the PlusNet service, whcih has been mirrored in some other topics.
I noticed the same early this morning around 06:00-06:30hr when I was downloading stuff from iplayer. Unless the Beeb were throttling their servers I was struggling to get 1/8th of the normal download speed!
A speed test confirmed to me that something fishy was afoot. I just checked and PTN-AG1 does not show any dropped packages at that time in the morning. I had to run to get to work so I didn't troubleshoot it any further. Any ideas?
