Netgear WNR1000v3 Router Flaky After Update
- Netgear WNR1000v3 Router Flaky After Update
11-01-2012 11:18 PM
It's now incredibly unreliable. It constantly drops wireless and wired connections (wired connection will only come back up after a reboot), yet remains connected to the internet.
Is it possible to downgrade? I'd stick DD-wrt on it if it was fully working for this model.
Re: Netgear WNR1000v3 Router Flaky After Update
12-01-2012 7:25 AM
Many routers exhibit unpredictable behavior after an update because the configuration memory has not been correctly initialized, so clearing the configuration back to factory default and then re-entering the settings from scratch, will often sort things out.
12-01-2012 7:28 AM
It did improve the wireless slightly but the wired network stayed the same.
12-01-2012 7:44 AM
Quote from: J I have a plusNET supplied Netgear WNR1000v3 router which decided to upgrade itself to V1.0.2.42_55.0.77 today.
If it "upgraded itself", I am wondering what is going to happen if you load a previous firmware release - is it going to "upgraded itself" again ?
You could get a previous version from here - http://support.netgear.com/app/answers/detail/a_id/16495
Make sure you press the "Restore factory settings" button for 10 seconds after doing the update.
12-01-2012 8:13 AM
You can switch the update check off, so if I can get it stable again I'll do that.
12-01-2012 1:55 PM
next one am about to buy is the Cisco WRT610N (same as the E3000)......
I'll then ask if PN will want there happy shopper WNR1000 router back, or whether i can sell it for 25p, or 10p if i am lucky
Rubbish routers, firmware upgrades will probably still make it rubbish !
12-01-2012 2:12 PM
Shame it [Censored] everything up.
Edit: I didn't think that was technically a swear word. Pretty sure you'd hear it on the Beeb any time of day... Sorry
14-01-2012 11:20 PM
Quote from: J Thanks. I'll try downgrading tonight.
Jim did you have any joy downgrading the firmware? I upgraded my WNR100v3 to the latest version which has created the flakey wireless issue. When I try and install an older version I get the warning about it being an old version, and if I continue anyway it stops installing. I tried the recovery disc but that says its not corrupt so also doesn't work. Any suggestions?
14-01-2012 11:53 PM
Did you get the european firmware?
15-01-2012 10:56 AM
16-01-2012 8:01 AM
Why must I always be curious and upgrade
17-01-2012 7:29 AM
Will PN be contacting Netgear about the issue? Or is it just a case of user beware when it comes to updated firmware?
07-02-2012 7:44 PM
edit
Already I can see a marked improvement
