Netgear WNR1000 Keeps on disconnecting
- Netgear WNR1000 Keeps on disconnecting
05-01-2014 12:05 AM
My Plusnet provided netgear WNR1000 keeps on randomly disconnecting and rebooting itself.
Have done a factory reset on it to no avail.
I wonder whether plus net would send me a replacement router?? Maybe not Netgear as I don't rate the performance of it that well especially with Wireless-N speeds.
Message 1 of 3
(707 Views)
2 REPLIES 2
Re: Netgear WNR1000 Keeps on disconnecting
06-01-2014 11:01 AM
Message 2 of 3
(379 Views)
06-01-2014 5:18 PM
You should probably take up Adam's offer if your Netgear's not working properly. However, do have a look round the forums and see what people are saying about the 582's wireless performance. It doesn't seem to be all that good. You could still use it as a backup if you later buy something with better wifi.
I seem to have been a bit luckier than you. My WNR1000 is still going well (2.5 years old now) and I'm happy with its wireless performance. It's only N150 standard, but I went back to it after having had a ZyXEL NBG4604 (N300) during the 80/20 fibre trial because the WNR1000's actual performance seemed just as good and I liked some of its other features. Mind you, at the time I didn't have any devices that could take advantage of N300 speeds.
Graham
Graham
Message 3 of 3
(379 Views)
