turn on suggestions
Netgear WNDR4500 (N900) with plusnet fttc
- Netgear WNDR4500 (N900) with plusnet fttc
06-07-2012 9:06 PM
HI
Can anyone confirm that this router will work with the plusnet fibre optic package. (i intend to ditch my techicolor when it arrives)
Has anyone had any experience with this - any set up issues etc.
thanks in advance
j
thanks in advance
j
1 REPLY
Re: Netgear WNDR4500 (N900) with plusnet fttc
07-07-2012 2:42 PM
It supports PPPoE so yep, will happily work.
I dont have fibre, or a WNDR4500 (Ive got the WNDR4000, the N600 version running with an ADSL Modem, 4000 and 4500 are similar as far as i know, just wifi speeds are different) - I didnt have any set up issues with that one, so you should have a similar experience with your N900.
