Netgear WN2000RPT extender
- Netgear WN2000RPT extender
09-05-2013 11:54 AM
Does anyone use an extender or can they tell me if the above is compatible with the technicolor TG582n router. It used to work but now I have changed to fibre broadband it works if I put an ethernet connection in but not with wifi. It asks for a code / password but none seem to work.
I cannot eeven bring up the setup wizard on it.
Anyone help
Anyone help
Message 1 of 4
(767 Views)
3 REPLIES 3
Re: Netgear WN2000RPT extender
09-05-2013 1:18 PM
The address of the extender will still be in the range of your old router, not the 192.168.1.xx range of the technicolor. I suggest that you reset the extender and start again. The instructions are here:
http://www.downloads.netgear.com/files/GDC/WN2000RPT/WN2000RPT_UM_8Dec10.pdf
Message 2 of 4
(458 Views)
10-05-2013 4:42 PM
Frank
many thanks some how I managed to sort it don't know how but it works. Thanks for the response though
Message 3 of 4
(458 Views)
10-05-2013 6:27 PM
If it works, that's fine and I'm glad you've got it fixed. Would be nice to know how (just for information), but thanks for your response.
Frank
Frank
Message 4 of 4
(458 Views)
