Netgear Router Stats Logging
Luzern
Seasoned Pro
Logs show figures at minute intervals. Can the system be set to show figures at greater intervals? If yes please can someone say how?
VileReynard
Seasoned Pro
Fixes: 11
Re: Netgear Router Stats Logging
Try http://www.kitz.co.uk/adsl/frogstats.htm
This has details of how to get stats for many routers (including 4 netgear models).
It's try it and see though.
Luzern
Seasoned Pro
I am actually using the one Kitz writes of. but think minute interval is too close.
VileReynard
Seasoned Pro
Fixes: 11
I've got a DG384GT - it's possible to get a bundle of stats - although they don't mean much to me...
It involves using telnet to access the router interface so it would be a bit tricky to automate anyway.
Luzern
Seasoned Pro
Knowing my propensity to  ........... up things, I'll leve well alone for a substantial time being. OT but did a reconnect as speed dif not agree with profile. Down raised from 2300 to 4000 but Up has gone down from 380ish to 330.
Fixes: 63
Quote from: lucerne
I assume the answer is "yes", at least for graphing purposes.  There should be a configuration/set-up button or menu item, perhaps with a "cogs" icon, where this can be set.  Might be called "appearance" in the graphs section.
Sorry, that only partly answers your question but hopefully will help.
David
elementaltm
Alternative stats software for Netgear routers:
DMT tool http://dmt.mhilfe.de/
RouterStats http://www.vwlowen.co.uk/internet/files.htm
Just though this may help.
DM.
KABOOM!
