Netgear N600 DGND3700V2
- Re: Netgear N600 DGND3700V2
14-11-2012 9:41 AM
anyone using this (particularly interested in the V2) on PN and have any experiences to report.
I understand the V1 had some connectivity issues with some ADSL lines so will try to get a V2 but am also interested in experiences with the V1 in case I can pick up one of those cheap.
PT
PT
Message 1 of 4
(1,276 Views)
3 REPLIES 3
14-11-2012 4:28 PM
I had a V1 and it was a disaster. After a couple weeks use it would disconnect my broadband (at best every few days, at worst several times a day) and the only way to reconnect was to reboot the router. It played havoc with my DLM.
Netgear offered beta versions of firmware updates but to no avail. Netgear tech support then went quiet for a few months, during which I returned my router for a refund. Netgear later came back with an offer of a v2 but too late, I had replaced the 3700 with the PN router 582n, a gigabit switch and a WD Mybooklive for the same cost and better reliability.
Frank
PS haven't we had this discussion before?
PPS. I have found it, we were discussing the 582n reliability before I bought the Netgear. As you can see, I reverted to my 582n.
Frank
Message 2 of 4
(548 Views)
14-11-2012 4:54 PM
Thanks, I am hoping the probs with V1 have been ironed out hence me asking if anyone is using a V2 on PN
PT
PT
Message 3 of 4
(548 Views)
14-11-2012 5:03 PM
The Netgear 3700 forum doesn't look that promising
http://forum1.netgear.com/forumdisplay.php?f=115
But I guess you have already been through that lot, I haven't looked at it since I dumped mine in April.
Message 4 of 4
(548 Views)
