Netgear N300 router help please
- Netgear N300 router help please
21-06-2011 1:08 PM
just got a netgear N300 to replace my BT 2110 router cant plug in till later as unable to reach socket but ion the BT router there is a number SSID (is that right) that i put in on my iphone laptop etc to access the wireless network which is just called voyager 2110 by default as i only use wireless,
on the new router there is no sticker on the bottom or in the box with this info so how do i connect wirelessly
thanks in advance for any help
Re: Netgear N300 router help please
21-06-2011 1:40 PM
21-06-2011 1:46 PM
do i have to connect the cable or can i do it wireless and configure a password? and if i cant then after can i then just discard the wired connection as we are all on laptops here my home computer is now gathering dust in the spare room
21-06-2011 1:56 PM
then
192.168.0.1
Username - admin
Password - password
change wireless settings.
21-06-2011 1:59 PM
WEP
WPA-PSK
WPA2-PSK (AES)
WPA-PSK (TKIP) + WPA2-PSK (AES)
that really means nothing to me all i know is my voyager is WEP which one should i use??? please
thank you again for your help it is gratefully received
21-06-2011 2:12 PM
probably the most secure and compatible
its the mode i use.
21-06-2011 2:20 PM
maybe by the sounds of it i dont need to use the cd this time
21-06-2011 2:36 PM
21-06-2011 3:51 PM
The best thing to do with the DGN2200 is to use the disc that came with it, it's an easy set up and sets up your wireless security as well as detecting your internet connection.
Jojo
21-06-2011 4:04 PM
Jojo I'll post back on my original thread in a couple of days for an update on the graph especially as i may not have found where the router shows how long i have been connected lol
21-06-2011 4:41 PM
21-06-2011 8:32 PM
oh and does anyone know where on a Netgear N300 i see how long i have been connected as i cannot find it anywhere.
21-06-2011 8:39 PM
Quote Click the Show Statistics button on the Router Status screen
21-06-2011 8:46 PM
oddly it worked once and now when i click nothing tried reloading browser strange and annoying
22-06-2011 2:40 PM
