Netgear DGND3700 : Does it work for a fibre installation
- Netgear DGND3700 : Does it work for a fibre instal...
05-07-2012 3:17 PM
I bought this router about a month ago, and it just occurred to me that if I upgrade to fibre in the not too distant future, it might not work.
Can anyone confirm if it will work ok with a fibre installation or not.
Cheers!
Cheers!
Message 1 of 3
(705 Views)
2 REPLIES 2
Re: Netgear DGND3700 : Does it work for a fibre installation
05-07-2012 3:22 PM
According to the specs it should work fine as a fibre router:
Quote Cable or Fiber: Connects to cable modem via Gigabit Ethernet WAN port
Message 2 of 3
(292 Views)
05-07-2012 3:27 PM
Thanks Chris
Message 3 of 3
(292 Views)
