Netgear DG834GT shows connected but does not load webpages
- Netgear DG834GT shows connected but does not load ...
23-08-2010 5:23 PM
Re: Netgear DG834GT shows connected but does not load webpages
23-08-2010 5:29 PM
Have you tried using an IP address - put this one in the browser 212.58.224.138 and see what happens
This is what I get
Quote BBC - Public Service Message
Sorry, the address you are looking for is not available.
You will find almost all BBC public service content on http://www.bbc.co.uk/ and by following links to the content you require.
To access specific areas directly you can type the address in the format: http://www.bbc.co.uk/'service or programme title'
e.g. The Radio 1, BBC One and BBC Weather websites can be found at the following addresses:
* http://www.bbc.co.uk/radio1/
* http://www.bbc.co.uk/bbcone/
* http://www.bbc.co.uk/weather/
Alternatively you can search bbc.co.uk:
23-08-2010 5:36 PM
23-08-2010 5:39 PM
IP Address xxx.yyy.180.59
Network Type PPPoA
IP Subnet Mask 255.255.255.255
Gateway IP Address 195.166.128.242
Domain Name Server 212.159.6.9
212.159.6.10
Do you see something similar? You should not normally need to manually tell the router what DNS addresses to use, unless you don't want to use Plusnet's DNS servers.
(I have hidden the first part of my current IP address).
23-08-2010 5:45 PM
23-08-2010 5:46 PM
IP Address xx.yyy.108.188
Network Type PPPoA
Gateway IP Address 195.166.128.236
Domain Name Server 212.159.6.10
212.159.6.9
The only difference (besides the IP adress) is the Gateway IP Adress. Is that the problem and if yes, how would I change this.
23-08-2010 8:55 PM
Hoppere, that all seems in order. Your router has a perfectly good connection to the internet via Plusnet so something on your computer must be overriding the settings. What do you get if you open a CMD window and type ipconfig /all <enter>. You should see something like this (I have removed a lot of the extraneous stuff):
IPv4 Address. . . . . . . . . . . : 192.168.0.20(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 23 August 2010 18:02:27
Lease Expires . . . . . . . . . . : 26 August 2010 18:02:26
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DNS Servers . . . . . . . . . . . : 192.168.0.1
23-08-2010 11:27 PM
here is what I got:
IPv4 Address. . . . . . . . . . . : 192.168.1.68
Lease Obtained. . . . . . . . . . : 23 August 2010 17:42:43
Lease Expires . . . . . . . . . . : 24 August 2010 17:42:43
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DNS Servers . . . . . . . . . . . : 192.168.1.254
24-08-2010 8:49 AM
Its highly likely that the Netgear is using a different local subnet ( 192.168.0.x ) to the Thomson ( 192.186.1.x ), maybe your firewall is blocking the changed subnet ?
24-08-2010 10:17 AM
25-08-2010 3:59 PM
