Negnet problems
- Re: Negnet problems
Negnet problems
04-02-2014 1:01 PM
jim:green quote removed after posts split off mod;end
Re: Negnet problems
04-02-2014 1:13 PM
Sorry to hear that you're so unhappy. I've just taken a look over your account and can see that your direct debit was changed but there wasn't enough time to set up the new one prior to your payment going out. As you obviously wanted to pay by DD I'm happy to refund the £1.50 non-dd fee back to you.
With regards to the slow speeds, it doesn't seem that you've ever reported this to us, unless you tell us you're having a problem we're not going to know to look into it. If you're still seeing problems with your connection then please go through the steps at https://faults.plus.net
Re: Negnet problems
04-02-2014 1:13 PM
Calling them a bunch of thieves and slating/badmouthing another UK town / city isn't good forum etiquette !
Re: Negnet problems
04-02-2014 2:40 PM
i changed banks,11 different direct debits went through ,all except plusnets, why is this i wonder? as for connection speeds, its half of the 59 meg i was promised. why is this i wonder? there is no faults,just a slow gradual degredation of speed. i have read the forums and it seems this is common for plusnet. the more people join the less speeds everybody gets. if you increase my speed someone elses will suffer. like i informed people over the phone at plusnet, watch the forums and review sites. im from sheffield myself and because plusnet accepts no responsibility for their mistakes i will convey this to as many people as possible.
Quote from: Chris Hi there,
jim:green Link corrected after posts split off mod:end
Re: Negnet problems
04-02-2014 2:43 PM
l am proud of sheffield,we say it like it is, unless you get paid by plusnet that is.
Quote from: DomS Maybe if you post some of your issues on the forum Negnet, some of the staff / customers on here may be able to help ?
Re: Negnet problems
04-02-2014 2:45 PM
It's really not as simple as giving some people more speed than others. If you're getting lower than expected speeds, we'd be more than happy to take a look over things for you.
Re: Negnet problems
04-02-2014 2:54 PM
You could have a totally unrelated issue though with your wiring or equipment so it is worth giving PN a chance to try and figure out what is going on as you could quite possibly have exactly the same issue with whoever you move to.
Re: Negnet problems
04-02-2014 2:55 PM
how complicated is it? am i wrong in my assertions?the more people who join plusnet the less overall speed everybody gets.
Quote from: Chris Is there anything we can do to help at all?
Re: Negnet problems
04-02-2014 2:57 PM
http://usertools.plus.net/status/archive/1391518086.htm is an example of this.
Re: Negnet problems
04-02-2014 3:03 PM
i was getting way over 70 mb now im way under 30. , i am not going through the diagnostics again.plug this in ,disconnect that, i did this with my old company,again and again. if you complain they raise the speeds for a while before slowly taking the increases away. anyway i was promised 59 now less than 30. in fact the plusnet test says i only have 1 meg download.
Quote from: DomS The degradation of speed on FTTC seems to be a fairly common occurrence between ISPs (not just PN or BT). As more customers join the cabinet, there is more crosstalk between the wiring and the speed drops to compensate and give a more stable line. My next door neighbour is with TalkTalk FTTC and she has had a similar drop in speed to me over the last year. Mine went from around 73Mb/s initially to a pretty stable 65Mb/s. It is currently sitting at 60Mb/s but usually a BT modem reboot brings it back up to around 68-69 then settles at 65.
Re: Negnet problems
04-02-2014 3:06 PM
thanks, but i think doms post explains why speeds are slower
Quote from: Chris The more customers that move over to Plusnet, the more capacity we add.
Re: Negnet problems
04-02-2014 3:15 PM
Re: Negnet problems
04-02-2014 5:02 PM
(Sorry TOPRC for hijacking your thread !).
If he hasn't raised a ticket or called in previously to report the issue then obviously nobody can help.
negnet - the same issue could/would happen with the crosstalk and slowdowns if there were for example 30 Plusnet customers on the cabinet or 15 Plusnet and 15 BT customers or even 10 Plusnet, 10 BT and 10 Entanet customers.
If however you've experienced a serious slowdown in speed, since installation there could well be a hardware issue somewhere. What does the BT speed test here ? http://speedtest.btwholesale.com/
Also run the extended test and post back the results. Make sure you do this test on a wired connection as wireless test results are notoriously unreliable.
Re: Negnet problems
04-02-2014 5:16 PM
Quote from: negnet i was getting way over 70 mb now im way under 30. , i am not going through the diagnostics again.plug this in ,disconnect that, i did this with my old company,again and again. if you complain they raise the speeds for a while before slowly taking the increases away. anyway i was promised 59 now less than 30. in fact the plusnet test says i only have 1 meg download.
The Plusnet test is not reliable - there is a warning on the test which says :
Quote Please Note: We are currently experiencing issues with our speed tester and results may not be 100% accurate.
My speed has been tested at 6 meg download - my actual speed is ten times that. A more liable test is the www.speedtest.net site.
Who were your previous ISP and what issues did you have with the speed there - it sounds like you might have issues with your lines if you moved to Plusnet and are still experiencing speed issues.
Re: Negnet problems
04-02-2014 7:05 PM
restricting peoples internet and broadband is despicable. i would not mind but we was one of the first to get plusnet SUPERFAST bb and we have never missed a payment.
AND MY GRIPE IS WITH HOW YOU TREAT YOUR CUSTOMERS / NOT ABOUT SPEED AT ALL.
dick:quote
