Need more speed!
fwibbler
Need more speed!
I currently have the Premier Option 1 package (which I'm quite happy with) but it's still at the ole speed of 2Mbps.
I was wondering if it's possible to keep the same package but move to the higher 'upto 8Mbps' speed?
According to BT's line tester, I should be able to get upto 5.5Mbps which seems like a worthwhile increase.
Cheers!
pierre_pierre
Re: Need more speed!
just put in ticket and request it - no charge
http://max.plus.net used to be the link, but I think nowadays you just raise a ticket asking to be upgraded to the 'Max' product.
B.
Fixes: 165
If you haven't raised a ticket, I'll pick this up and place the order for you in the morning. It'll complete on the next working day (Tuesday).
 Chris Parr
 Plusnet Staff
fwibbler
That would be great thanks.
Do I still need to raise a ticket or will you just remember it?
Cheers!
James
You're actually already on Max.
Can you try rebooting your router and see if you get faster speeds?
Fixes: 62
it would help if you posted the router stats
Sync speed, attenuation, noise margin
fwibbler
This makes me look like a right numpty!
I swear on all my previous Speedtest.net results I've been getting 1.8 - 1.9Mb/s.
Now this evening I try it (without rebooting the router) and get 4.54Mb/s, which is great.
I'll keep an eye on it for a while.
Thanks.
James
I wouldn't feel too much like a numpty Smiley
I had to do some manual changes to your account first to get your speeds up to where they should have been.
fwibbler
Ah right. (Phew! thought I was loosing it there)
In that case, thanks very much for whatever you did.
Cheers!
