Need To Resolve Speed Issue
- Need To Resolve Speed Issue
Re: Need To Resolve Speed Issue
27-03-2009 10:36 PM
Cheers
Yes jelv, I do have a connection socket with that symbol, so it does look like I'm set up for ethernet. Thanks.
More interestingly however, there seems to be a concensus building that I'm NOT on IP Stream Max ( see previous posts by Maurice, Adiewoo and HP Sauce - a suspicion shared by myself).
Jamesh @ Plusnet. Can this be bottomed out please? Despite you saying I am on Max , my experiences, the results and the replies seem to say I'm not. Doesn't all this warrant some further investigation by Plusnet?
Adderman
27-03-2009 10:44 PM
here is part of a Plusnet reply I received on 14th January 2009 in connection with my speed issue:
"I have looked through your account and I cant see any reason to why we would be limiting you ..............."
Is this not a part acknowledgement that my speed is being restricted?
Adderman
27-03-2009 10:44 PM
B.
27-03-2009 10:49 PM
Adderman
27-03-2009 10:52 PM
Either PN need to correct their systems OR they need to put a boot up BT's a**se - either way it's for PN to sort out so raise a ticket.
Your modem will run up to 8mbps but it's always better to have a router (especially on Max) and your PC appears to be capable.
Suggestion: PN supply you with a free one and waive the delivery charge by way of recognition of the SNAFU on your line speed.
27-03-2009 10:56 PM
I have flagged this up for a rep - hopefully tomorrow but possibly not until Monday
28-03-2009 7:51 AM
OK - I won't raise a ticket (again!) until I've heard back from oldjim's-(thanks old')- request for a report. Sooner the better I hope.
HP - as above and thanks again. (This palaver has echoes of when I asked to transfer my phone service from BT to Plusnet a while back. P/Net said it would take ten days - it ended up taking 3 months - and only after I had to resort to a forum posting)!!
(On a general note- following all suggestions I'll consider changing to a router but you'll all understand that I want Plusnet to get to the bottom of this first. I'll post any info I get from them.
I wait with baited breath!! Off to work now (another groan!!)
Adderman
29-03-2009 4:07 AM
29-03-2009 11:33 AM
Sorry mate - I haven't been able to do that - but if anyone can help with that I'll try.
Cheers
Adderman
29-03-2009 1:06 PM
Here is are some broadband checker results included in a reply to my original ticket about my speed issue. This info might be what your'e looking for?
Link:CSA Removed BOT - DSL Logged Faults 5:33pm, Wednesday 21st January 2009
INTERNAL:
Upstream Link Info
Loop Loss Loop Loss Add Text SNR Margin Errored Seconds HecErrors Cell Count Speed
17.5 24.7 0 0 6104160 288
Downstream Link Info
Loop Loss Loop Loss Add Text SNR Margin ErroredSeconds HecErrors CellCount Speed
42 19 0 0 48437069 2272
DSL Max Data
BIP Interface Data
Current line rate Line rate change timestamp Maximum Stable Rate Recalcuated ProfileTimestamp Maximum Stable Rate
2000 2008-10-28T00:15:00 N 2008-10-29T13:53:44 2272
Fault Threshold Rate Interleaving Flag ServiceOption ServiceOption Status ServiceOption Update Timestamp
1817 I 1 UNABLE TO REACH THE CHOSEN SERVICE OPTION BUT WILL CONTINUE TO FUNCTION UNDER DLM CONTROL (ILQ=R) 2008-10-28T06:10:50
adie:red CSA removed as per link:rules]
29-03-2009 1:22 PM
Cheers
Adderman
29-03-2009 3:32 PM
That said you've inadvertently provided sufficient information to confirm a number of suspicions held by jelv, Maurice, HP, OJ and self. This is NOT running as a true maxDSL service. With that line data you should be capable of syncing around 5M currently and under ideal condition approaching 6.5-7M.
Here is a question for James, what exactly does this mean?
Quote Fault Threshold Rate Interleaving Flag ServiceOption ServiceOption Status ServiceOption Update Timestamp
An explanation would be nice to broaden all our kowledge base, rather than - "there's something wrong there".
I would have thought "a rat should have been smelled" some while back and a futher investigation taken place especially in the context of the test results, I'd guess the others would agree with me.
29-03-2009 8:41 PM
Sorry, I've looked at the driver install disc and checked the basic Quick start Guide - these were all I was supplied with - and neither tell me how to obtain any kind of in-depth info.
Respecting everyone's advice I fully intend now to change to a router (any recommends anyone? I'll pay whatever, provided performance justifies cost. Also been researching best filters - the XF-1e pro gets good reviews). Downside is 'cos of long working hours can't do anything about this until late next week.
But regardless of my own time restrictions it looks like Plusnet still have plenty of explaining & work to do. Let's hope everyone's comments shake them from their apparent apathy.
Adderman
30-03-2009 1:27 AM
ZyXEL Prestige 630 USB modem
To access the advanced Features
Hold down Left Shift + Left Ctrl and then click on the ZYXEL logo.
Click the Advanced Button that appears to get a window showing your line stats.
David
30-03-2009 10:18 AM
If he wasn't, he wouldn't be getting that view on the BT Speedtester (and thanks for the PM telling me I was wrong, Adie).
It suggests to me that it is a capped IPStream Max circuit. We could try resolving it via one of two avenues.
1) Raise a fault with BT
2) Downgrade to 2Mbps fixed and then reupgraded to IPStream Max.
I suspect that the second is probably going to be the quicker option as each order will take 24 hours.
