Need To Resolve Speed Issue
- Need To Resolve Speed Issue
Re: Need To Resolve Speed Issue
30-03-2009 10:27 AM
30-03-2009 6:38 PM
30-03-2009 7:23 PM
I'll try option 2 as you suggest.
Can you take this message as authorisation for you to do this?
Also can you tell me if I need to do anything to help it along, and what I can expect - ie how long? service interruptions? etc etc. Thanks Adderman
Spraxyt - appreciated. I'll defer on this pending results of Jamesh's actions as above.
Pierre_Pierre - Been with PN since April 2006 so the transfer thing wasn't an issue, but thanks anyway.
adie:green removed 2 acres of whitespace :)]
31-03-2009 6:05 AM
a bit of editing of that dead space in the previous post would help if a mod doesn't get there first. It doesn't matter what actions are being taken to sort your issue, you still need to learn how to read your stats so you can monitor what is happening on your line.
Edit: Comment to James removed - wrong thread, sorry.
31-03-2009 7:26 AM
Taken on board ;). Actually I've just tried spraxyt's suggestion above and nothing happens. There isn't a ZyXEL logo that appears. I'll give it another go tonight.
Ta
Adderman
PS ref: my previous post. I've raised a ticket for Jamesh anyway.
31-03-2009 8:11 AM
and if you can find it hope it works
31-03-2009 9:23 AM
I've just seen your post.
I'll get the up/downgrade order placed now. It'll complete tomorrow.
31-03-2009 8:18 PM
Adderman
01-04-2009 1:18 AM
Quote from: Adderman Actually I've just tried spraxyt's suggestion above and nothing happens. There isn't a ZyXEL logo that appears. I'll give it another go tonight.
I imagine the logo you are meant to click (or should it be double-click?) is that for the modem already shown in the system tray. If there isn't one there I think you would have to find it in Control Panel.
David
01-04-2009 8:40 PM
Status: Connected
Speed: 2.2Mbps
Compression: 0%
Errors: 0
I think the posters on here were looking for something a bit more meaty like:
Atten/Loop loss
Sync speed/Rate/Connection
SNR/Noise/Margin
CRC/HEC/RS/FEC errors
Adderman
02-04-2009 2:20 AM
After a bit of Googling I think the instructions I gave probably apply to a different device (router/modem) for which ZyXel also used the 630 series number, though it's a different model.
02-04-2009 9:47 AM
Your order should now have completed, what speeds are you seeing now?
03-04-2009 9:50 AM
James - tray icon now indicating speed of 7.3/7.4 Mbps so many thanks I'll keep an eye on speed over the next ten days or so ("training period"?). I have momentarily lost connection a couple of times but guess this has something to do with the speed reconfiguration which needs to settle down? Also James I've ordered a router: do I hold off changing from modem to router during the training period, or is it ok to install router straight away? Ta
spraxyt - thanks again. see above re imminent change to a router. I'll put trying to get my modem stats to bed!
Cheers
Adderman
03-04-2009 11:20 AM
One tip, don't just unplug the line from any modem/router. Best to powerdown and wait a minute or two before unplugging the line.
You can 'talk' to your router interface, find your way around how to access the stats etc. without it connected to the line. Might be best to have a short 'play' before you connect your line.
Oh, do this FIRST. Check in Device Manager that your Ethernet port is enabled, and working properly (ie. all the drivers correctly installed etc.).
That current sync speed of 7.3./7.4 is probably a touch high for you line attenuation (if that figure from the previous PN test is still current/correct) hopefully it won't settle down lower than 6816, if your lucky it might be 7392 or a touch higher but we'll have to wait and see the line stats to make a better judgement on that.
03-04-2009 6:12 PM
Q: I understand that routers don't place drivers on my computer. Will it be ok then to leave my original modem drivers installed - without them interfering with router set up - just until I'm satisfied that the new router works ok? (My thinking is that if the new router turns out to be a dud I can just revert instantly and temporarily back to my modem pending acquisition of a replacement router).
Ta
Adderman
