Nearly at the limit !
Fixes: 16
If this is in the wrong slot, please move it....
I have just received a coutesy email saying I am nearly at my limit of 15gb.... and checked my usage and the summary states I have been doing some gaming on line (about 4% of usage)... Oops... I don`t do that....
and 25% of the usage is allocated to peer to peer....
not knowing what peer to peer means, I am assuming it may have something to do with chatting on flickr photophlow.....?  is this correct.....?
There is also an allocation of about 8% on "other" whatever that is....
Fixes: 62
Re: Nearly at the limit !
Not sure about Flickr but do you use Spotify as that uses P2P
Moved to Community Support as that is where this is usually discussed
Fixes: 16
No, I don`t use spotify.... Photophlow is part of flickr and you can have your own chat room, or one that is set up by a particular group,  I have been using it quite a lot recently, and wondered if that was the 25% on P2P allocation.....(If it is, then I shall have to shutup ! ! ....it does get addictive ! !)  Roll eyes
Fixes: 62
It may be wrongly identified although apparently Photophlow downloads large pictures without asking and ignores the main Flickr settings
