Nearing my usage limit
Got the warning email last night:
You're approaching your product's broadband peak-time usage allowance of 15GB for this month. We've sent you this email to help you manage your usage, and ensure you don't face unexpected charges.
There's no limit on how much you can use, but once you've used your 15GB allowance, additional usage is charged at £2 per 2GB.
Current  paid for usage stands at  12.04GB with the end of the period being this weekend
I'm on Broadband Your Way Option 2 and I didn't that the auto extend allowances were available on that product, only on Pro.
James
Re:Nearing my usage limit
Hi Steve,
You can (if you want to) automatically add extra usage in a PAYG fashion on BBYW.
Re: Nearing my usage limit
OK thanks, I didn't know and the email implies that it will happen automatically and that I can put a pay cap on it if I wanted.
Fixes: 21
I thought on BBYW products it was £1 per 1GB?
Fixes: 162
That depends on which BBYW product you are on:
http://www.plus.net/support/broadband/products/archive/bbyw/info.shtml#7
 Chris Parr
 Plusnet Staff
It is £1 per 1Gig but apparently I can't only buy 1 single Gig
As I've not set a price limit I presume that if I do go over 15GB then it will just bung another couple of quid on my bill?
James
If you usage isn't "fixed".  If it's set to PAYG, it'll just automatically add usage.
Fixes: 21
According to James's linky above (thanks James) you can. If the member centre isn't allowing you to, that was supposed to have been fixed
its not if the center wont allow me to set anything, but James' clicky says £1 per Gig but the email says £2 for 2GB which implies thats the smallest chunk they'll bill in. Now this close to the end of the month I might go over a bit but probably not by 2Gig, but id they're going to charge me for 2G extra then........
Fixes: 21
Ahhh  Smiley
Fixes: 162
BBYW Option 2 should allow you to buy in single GB chunks. Matt's detailed the info on the linked thread.
 Chris Parr
 Plusnet Staff
So I saw, hopefully I wont need it as I'll be off to the Sheraton at Heathrow in  a couple of hours.
