National Lottery website
acarneiro
Hi guys.
Just trying to reach teh National Lottery website (no, not quitting my job just yet! Tongue ) and unable to do so. Is It Down Right Now reports they can reach the site and a traceroute shows me the following
traceroute to national-lottery.co.uk (194.246.78.102), 64 hops max, 72 byte packets
1  192.168.0.1 (192.168.0.1)  0.610 ms  0.350 ms  0.347 ms
2  lo0.11.central11.ptw-bng01.plus.net (195.166.128.171)  12.759 ms  18.979 ms  13.951 ms
3  irb.11.ptw-cr02.plus.net (84.93.249.1Cool  17.261 ms  13.843 ms  10.080 ms
4  linx-fe0-0-barkley.lon.router.colt.net (195.66.236.49)  13.239 ms  19.615 ms  20.512 ms
5  * * *
6  cpeuk_lon066223.ia.colt.net (80.169.144.146)  10.612 ms  12.812 ms  11.645 ms
7  * * *
8  * * *
9  * * *
10  * * *
Any thoughts?
Thanks! Cheesy
Fixes: 6
Re: National Lottery website
I can access the site ok from here.
My tracert is much the same so that's not indicating much.
acarneiro
Much the same, including all the timeouts?
Fixes: 21
Working here atm.
Tracert much the same as well - with the timeouts. Not all routers on a path will respond to tracerts or pings, boring, but that's the way it is.
Fixes: 6
Yes including all the time-outs.
Time-out don't necessarily indicate a problem, it could be those hops are configured to not respond to ping.
The fact that your tracert shows the correct IP address also means this is not a dns issue.
Have you tried clearing your browsers cache?
You could try a different gateway.
they probably block icmp, site is fine here.
acarneiro
Thanks guys. You learn something new every day Smiley
Can't access from any of my computers or mobile phone. I think a router reboot may be in order Wink
Andre
