National Lottery website
- Re: National Lottery website
03-08-2014 8:41 AM
Hi guys.
Just trying to reach teh National Lottery website (no, not quitting my job just yet! ) and unable to do so. Is It Down Right Now reports they can reach the site and a traceroute shows me the following
traceroute to national-lottery.co.uk (194.246.78.102), 64 hops max, 72 byte packets
1 192.168.0.1 (192.168.0.1) 0.610 ms 0.350 ms 0.347 ms
2 lo0.11.central11.ptw-bng01.plus.net (195.166.128.171) 12.759 ms 18.979 ms 13.951 ms
3 irb.11.ptw-cr02.plus.net (84.93.249.18) 17.261 ms 13.843 ms 10.080 ms
4 linx-fe0-0-barkley.lon.router.colt.net (195.66.236.49) 13.239 ms 19.615 ms 20.512 ms
5 * * *
6 cpeuk_lon066223.ia.colt.net (80.169.144.146) 10.612 ms 12.812 ms 11.645 ms
7 * * *
8 * * *
9 * * *
10 * * *
Any thoughts?
Thanks!
5 * * *
7 * * *
8 * * *
9 * * *
10 * * *
Any thoughts?
Thanks!
Message 1 of 7
(1,040 Views)
6 REPLIES 6
03-08-2014 8:56 AM
I can access the site ok from here.
My tracert is much the same so that's not indicating much.
Message 2 of 7
(435 Views)
03-08-2014 9:24 AM
Much the same, including all the timeouts?
Message 3 of 7
(435 Views)
03-08-2014 9:42 AM
Working here atm.
Tracert much the same as well - with the timeouts. Not all routers on a path will respond to tracerts or pings, boring, but that's the way it is.
Message 4 of 7
(435 Views)
03-08-2014 9:53 AM
Yes including all the time-outs.
Time-out don't necessarily indicate a problem, it could be those hops are configured to not respond to ping.
The fact that your tracert shows the correct IP address also means this is not a dns issue.
Have you tried clearing your browsers cache?
You could try a different gateway.
Message 5 of 7
(435 Views)
03-08-2014 8:24 PM
they probably block icmp, site is fine here.
Message 6 of 7
(435 Views)
03-08-2014 9:31 PM
Thanks guys. You learn something new every day
Can't access from any of my computers or mobile phone. I think a router reboot may be in order
Andre
Andre
Message 7 of 7
(435 Views)
