Nat loopback
- Nat loopback
Nat loopback
02-01-2013 1:12 PM
On my network, I have a few devices (CCTV, Media server WHS2011 and satellite gear) that requires an external IP to be used to to be accessed internally, which modems without Nat Loopback firewall out. (The modem gets confused poor things!)
Anyway...... I did ask a question a short while back, that suggested it was possible with the modem provided, but havent seen any details on how its done.
Annoyingly, I spent a small fortune on a Belkin Gigabit Modem last year without realising it didnt support it..... but the time has come to lose the gigabit speed and get full functioning back!
Any pointers appreciated.
Re: Nat loopback
02-01-2013 1:40 PM
Hope that helps
Re: Nat loopback
03-01-2013 9:52 AM
As mentioned, someone had said it was possible..... I just didnt know how it was done!
I'll have a delve on Telnet CLI to see if I can find anything. I've got no problem in editing the .cfg - just not sure how access is gained!
adie:quote
Re: Nat loopback
03-01-2013 9:59 AM
Re: Nat loopback
03-01-2013 10:21 PM
PS... Mods... why did you edit my post above? If I did anything wrong. I'm unaware!
jim:quote
Re: Nat loopback
03-01-2013 10:57 PM
Re: Nat loopback
04-01-2013 9:09 AM
York.
Re: Nat loopback
04-01-2013 12:53 PM
Nedlud - cheers for that! I wouldnt have quoted you - but not allowed too!
(Hope I got the username spelt right!)
Hmmmm So last night I looked at my Belkin N600 gigabit router (which doesnt support Nat Loopback) to see if I could telnet and add that line. Opening up CMD and telnetting, simply said the telnet command wasnt valid. And using a telnet client, it opened a dos box then just died. I'm guessing that means it cant be telnetted. Does that sound right? Id much prefer to use a gigbit modem if I can, but if not... ho hum!
