My usage this month Zero!!!
hamilton36
Just checked my usage this month and it is shown as Zero? Clearly something must be wrong, but what?
Thanks,
Alex
9 REPLIES 9
tim11pop
Re: My usage this month Zero!!!
I haven't had any usage states since the first month I was with PlusNet!
I thought they'd just given up tracking it...
LinnPlusnet
Quote from: tim11pop
Hi tim11pop,
You will need to log into your router and change the log in credentials to the following your username here@plusdsl.net
Guides can be found here: http://www.plus.net/support/broadband/hardware/
LinnPlusnet
Quote from: hamilton36
Hi hamilton36,
I've added your account to an existing problem that we have open internally. You can find other information here: http://community.plus.net/forum/index.php/topic,127973.0.html
I'm sorry for any inconvenience caused by this.
wo0x
Mine's showing 134GB web, but only 33GB streaming.... That can't be right, I'd expect my streaming usage to be far higher than anything else.
Twills
Hi Wo0x,
It depends which internet port the streaming service comes from. Some streaming can come through HTTP ports making it look like web when its actually steaming. There is no way for the system to work out if its a webpage or a video Smiley
Twills.
xreyuk
Quote from: Wo0x
They've had a fault logged on their service status page about the usage monitor not logging at all, or logging inaccurate information. I'd suggest that's what could have happened (if the above didn't).
hamilton36
Quote from: Linn
Hi hamilton36,
Don't worry about the inconvenience, but I reported this nearly a week ago and the problem persists!  A whole week is a Century in computing, so what is happening, please?
Pettitto
Fixes: 5
It's not a simple fix unfortunately. Our Development Team are working with Vendors to get this fixed as quickly as possible.
As stated on other threads of a similar nature, you will not be charged for any usage used if you're on a usage capped product when your usage is showing 0KB.
petecov44
I didn't think people bothered with the usage breakdown any more. AS pointed out as nice as it is it's never accurate as explained above.
