My speed gone lower [solved]
- My speed gone lower [solved]
Re: My speed gone lower
25-11-2009 2:54 PM
Not sure how Im gona post all this, looks like I will have to do a few screenshots because I didnt do what you said to do earlier oops :<
Ive been watching a film and had a little kip, while this has been on going so I havent been aware of anything. There is no one else at home just me, so no ones been using the phone etc.
It looks like I got disconnected on the first picture, on the second picture it looks super good lol but then on the third, as its the current.. I duno whats going on
25-11-2009 3:03 PM
The third chart is worrying but also informative.
Something is happening to badly affect your noise margin. Have you anything coming on at those times in your property - something on a thermostat for example
Also from the first chart something probably switched off at about 10:56 - hence the jump in noise margin
25-11-2009 3:04 PM
Can somebody that knows how to use a detuned radio as a detector post instructions please.
25-11-2009 3:15 PM
I had a tuna salad at about half 10 - 11am so I didnt use the oven or microwave etc, all I did do was turn the tap on and opened the fridge
Ive had my tele on in my bedroom and ofcourse my pc, the skybox is on but I havent been using that. I was watching 2012 on the tele from the pc
Cannot think of anything else I have used today
As for neighbours I really wouldnt know! If it matters though, I live in a detached house and my house is actually on its own, further away than the others
25-11-2009 3:29 PM
How is your water heated - immersion heater or gas/oil boiler
25-11-2009 3:58 PM
Im not sure how my water is boiled though sorry, house is about 10 years old if you can make a guess from that... My guess is gas, but im not 100% sure. I would have to ask my dad later
25-11-2009 4:28 PM
http://boliston.wordpress.com/2009/03/15/sky-box-is-slowing-down-my-broadband/
Is this a known issue by you guys? My sky box is often on standby aswel
Or is this guy on wordpress.com talking poop?
25-11-2009 4:37 PM
If disconnecting the Sky Box seems to fix the problem you could try double filtering it.
25-11-2009 4:40 PM
Our Sky+ HD box actually stops us being able to use the phone.
25-11-2009 4:49 PM
it didnt drop when I first unplugged the sky box, it didnt do anything..
any ideas?
any other tests I can do, or what should I do now.
also by the way, what noise margin do i actually want? i dont even know whats considered good or bad
25-11-2009 4:58 PM
The actual noise margin figure doesn't matter so much, it's the significant drops that you want to eliminate.
I'd hope to see something like the attached.
25-11-2009 4:58 PM
While the noise level is lower go round switching off electrical items and see if any of them have an effect. You don't need to leave them off permanently. Just long enough to see if the noise margin rises then switch it on again and try the next one.
Prime candidates
Immersion heater
Fridge
Freezer
Electric heater
Note - don't mess about with your gas/oil boiler without talking to your father first
25-11-2009 5:03 PM
another picture.. another drop
25-11-2009 5:06 PM
25-11-2009 5:06 PM
The following items wil be switched on permanently but controlled by thermostats so that they will switch on and off all by themselves
Immersion heater (possibly on a time switch as well as a thermostat)
Fridge
Freezer
